Question about Haier ESA3087 Thru-Wall/Window Air Conditioner
Air conditioner fan doesn't run. Harier ESA3087.
  • 534 Answers
2 things could be wrong. 1 the fan motor has a capacitor that once it goes out the fan will not run. I would have this checked first because that in about 70 % of he time this is the problem.. 2 the fan motor itself has expired. I would change the capacitor first.. Good Luck
Dave
Posted on Jul 16, 2009
Goodman ck30-1l, outside fan trun on doesn't speed up and stops, what is wrong any ideas?
Your most likely issue is a bad run capacitor. It a small silver can that is usually located in the controls area of your condenser. If the fan has been replaced it could be mounted somewhere around the fan. It helps motors run and when they fail they will run half speed,
Jul 08, 2012 | Goodman CKL49AR49 Air Conditioner
Unit will not run. Changed the capicator and it still does not work.
what doesn't work? the condenser the fan the compressor ? need more details
Aug 12, 2011 | Goodman CKL42AR42 Air Conditioner
Unit shows e1 and will not turn on how do i reset it plus i have no remote for it
The only way to reset this is to unplug or remove power to the unit, wait 30 seconds and return power, If this does not work changing the control/display board would be the next step.
Jul 27, 2011 | Haier ESA3087 Thru-Wall/Window Air...
Just bought a 2 yr. old Danby DAC5209M window a/c unit that doesn't cool the air before it blows it into a room. The wiring looks brand new, it was barely dirty on the inside, anyway, I've...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 24, 2011 | Danby DAC5020 Air Conditioner
Hi, I have an amana ap125hd portable air conditioner and for some reason is doesn't produce cold air anymore. Then fan blows and the compressor kicks in, but to no avail, no cold air. I took the unit...
replace it,most likely the freon leaked out,if the compressor is running and the fan is blowing but not getting cold most likely you have a leak in the sealed system.
Jul 09, 2011 | Kitchen Ranges
The fan will not engage when unit is turned on and after 5 or so minutes the circuit breaker trips.
since the fan doesn't run - the compressor heats up and pulls excessive amps and trips the breaker.
99 out of 100 times your fan motor will be bad.
You need to replace the motor.
Jun 07, 2011 | Kenmore 74123 Air Conditioner
Power surge/Control Panel
The control board blew. You will need to replace the control board on your unit and everything will work correctly again. When a power surge happens it will blow the weakest link, and if your system is not on a protected outlet then the weakest link is your control board.
Jun 01, 2010 | Haier ESA3087 Thru-Wall/Window Air...
Haier ESA3087 Thru-Wall/Window Air Conditioner Logo
182 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Bonded Repair
Dan Apthorp
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
