Question about Dryers
It will heat for a while and went off. - Dryers
  • 97 Answers
Hello Friend, Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim. And please don't forget to give me your rating for my help.
Posted on Jul 11, 2009
My car was over heating I went and change the thermostat it was shot. went back to normal.
I think that your engine may have seized up. If the new thermostat was installed in the correct direction, I believe that the radiator was plugged up, which caused the engine to over heat. But it could also be that the impellers in the water pump have eroded away. I have never heard of a sensor that shuts off the engine during an over heat event. Excessive heat may have damaged the new thermostat.
Aug 18, 2015 | 2006 Chrysler Sebring 2.4
I have a Maytag Model LDE4916ACE dryer that recently the timer stopped woking two days ago, the next load it did the same went and went now today it does not heat. Any clue?
the heating element has overloaded and shorted out - new heat element is required along with a new timer switch .
Jul 23, 2011 | Dryers
Oven won't heat up
your heating element went bad repace heating element if stove doesnt come on at all the fuse went bad.
Feb 24, 2011 | GE Profile 30" Slide-In Gas Range -...
Went to plug in. Green light came on, no heat.
it's posible to have a disconected wire or a heating element burned. also is posible to have a problem whit saftey thermostat. good luck!
Feb 20, 2010 | Cuisinart WM-SW2 Sandwich Maker
Elec. in garage went out, heat from dryer didn't go on
Check the wall plug voltage for the dryer outlet with a voltage meter. The two holes on opposite sides of the wall outlet should read around 240V. Either of the two outside holes to the middle hole shoul dread about 120V. If your readings differ from these it's likely you have a problem with the fuse/breaker associated with the dryer or the person who fixed your heat made a wiring mistake.
Oct 03, 2009 | GE DBXR463GB Gas Dryer
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
Dryers Logo
48 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
