When put in reverse and given a little speed the motor rise'S up and when I let off on the speed the motor goes back down, everything else works very fine. except that proublum,
In reverse, the propellor is pulling the motor away from the boat, this is the same direction as the motion you get when you tilt the motor up for transport. Check the motor mount, especially the motor tilt mechanism to make sure nothing is excessively worn, bent or loose. Maybe the latch that's supposed to hold the motor in the run position isn't working right - that could be bad news if it lets the motor drop down while the boat is on the trailer.
