Question about Kenmore Dishwashers
I have a kenmore model 665.17779990 dishwasher that is leaking. I am collecting about one gallon of water coming from directly under the door during a normal wash cycle. The door seal does not appear to be the problem.
  • 10,515 Answers
Follow the below troubleshooting points :-
  • Inspect the seals for the main tub, float, heating element and blower diffuser
  • Check for overfilling
  • Inspect the water and drain hoses
  • Inspect the door gaskets
  • Check the water inlet valve
  • Check the pump
Check and you would find the fix.
Any other information, let me know.
Hope i helped you.
Thanks for using " Fixya " and have a nice day!!
Posted on Jul 11, 2009
Leaking from motor
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
God bless youc9c8c0e9-8a93-431d-b16a-9b8d97f35d28.gif14b36f01-1d58-4f2a-8f54-fc14feec17e3.jpg
May 23, 2013 | KitchenAid Dishwashers
I have got DWN 38 L Bendix dishwasher, problem is that during the wash cycle water starts to come under the washer. To ,me it looks like it can't take the water out.
If water is collecting under the dishwasher then there could be a few reasons.
1. door gasket is leaking - check for defect and replace if required
2. the wash or drain pump could be leaking water. Seals are not sitting properly or drain hose is cracked.
Feb 15, 2011 | Tricity Bendix 24 in. DH104 Free-Standing...
My Kenmore under counter ultra wash dishwasher model 665.15825691 has started leaking at the lower corners of the door. The leaks seem to occur during the final rinse while the water is being heated. I...
Happened on my dish washer too. Remove lower rack, remove lower spray arm by removing the center plastic nut, check screws (torx) on outside edge of pump. Tighten these as necessary, mine were loose causing water to spray forward against the tub causing leakage.
Jun 27, 2009 | Kenmore Dishwashers
Water comes out the bottom of the door. not
With very few exceptions, when a dishwasher leaks as you describe, the door gasket needs to be replaced. You have not posted the manufacturer and model number, so it is hard to help much more. Please post back here with further questions.
Good Luck!
May 04, 2009 | Kenmore Dishwashers
Dishwasher leaks during rinse cycle
it sounds like you need to adjust the door latch so that the top of the door will close tighter. when in the rinse cycle try pushing door at top to see if leak stops. if that doesn't let you know something then you got me. you have changed all that i can think of. Good luck
May 01, 2009 | Dishwashers
I have a kenmore elite and none of my dishes are coming out clean
Well, if the motor is moving, try adding a half gallon of /hot/ water before you start the cycle (just pour a saucepan full directly into the dishwasher). If that sounds like it is doing a lot more "blasting" than it was before- you probably need a new water inlet valve, or perhaps to take your water inlet valve off and try to clean out the screen. Problem being, you arent getting enough water into the washer before it starts washing.
It is located at the front of the machine behind the panel under the door.. but as a check, make sure that the valve under the sink that sends water to the dishwasher is all the way open, as this can cause the same problem.
If you do decide to remove the valve, be sure to cut the power at the breaker, or unplug the dishwasher, and turn off the water valve under the sink.
Apr 18, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher leaks during the wash and rinse cycles from the front
Without knowing the model number of this Sears Kenmore dishwasher, it is difficult to be specific in a solution.
There is a float/switch that controls the amount of water added before each wash or rinse cycle. Replacing that float would be the first step.
Can not be more specific without knowing the model number.
Apr 04, 2009 | Kenmore Dishwashers
18 in dishwasher drains water during cycles
find out how the dishwasher is set up to drain. Pour water into dishwasher 4 or 5 gallons, see if water disappears. if so, your drain is ran wrong
Jan 05, 2008 | Kenmore 15121 Built-in Dishwasher
Leaking on floor only after shuts down.
Griz, check the vent and see if you have bunch of gunk thats collecting water in it. Sometimes the spray arms are cracked and direct water into the vent. If this happens you will have leaking down the center of the door. Catriver...post back
Aug 14, 2006 | Kenmore 18 in. 14432 / 14439 Built-in...
Dishwashers Logo
27 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
