Sewing Machines Logo
p
pamela Posted on Jun 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bernina 430 need manual
R.A. Ellis
Level 3:
  • Bernina Master 12,731 Answers
  • Posted on Jul 05, 2015
R.A. Ellis
Bernina Master
Level 3:
Answers
12731
Questions
Helped
2613441
Points
59176
Go to Berninausa.com, select Support, and then Support for Bernina Models, then scroll down to the link for the 430.
BERNINA Support Machine and Accessories Finders and Software Support...
Ruth summersides
Level 3:
Genius:
  • Bernina Master 1,493 Answers
  • Posted on Jul 02, 2015
Ruth summersides
Bernina Master
Level 3:
Genius:
Answers
1493
Questions
Helped
362844
Points
2425
Try manufacturer or manuals on line.com
1 Related Answer
Anonymous
  • 51 Answers
  • Posted on Sep 16, 2010
SOURCE: don't know how to lower feed dogs on my Bernina 430-
http://www.tradebit.com/filedetail.php/32156673-janome-memory-craft-9000-instruction-manual
Which artlink is compatible window7, aurora 430 and embroidery unit.Artlink6 is working but doesn't allow me to write to machine.Editor lite v4 doesn't pick up dongle.Nothing wrong with USBports
This sounds more like a driver issue than a software problem. The ArtLink 6 software CD that came with the Aurora 430 had drivers for XP and Windows Vista. However, these drivers may have only been for the 32-bit OS. Windows 7 is the first version of the OS to have had a large number of 64-bit installations.
The latest drivers for the Aurora 430 is available here: https://berninaofamerica.zendesk.com/hc/en-us/articles/200183069-Aurora-Driver-Windows-Vista-7-and-8- . You will need to install two drivers; follow the directions on the site. Make sure that the USB cable is good and that you aren't using a USB hub.
If you have installed the drivers and the ArtLink 6 software still isn't working, ArtLink 7 is fully compatible with Windows 7 and the Aurora sewing machines. The only download site for this software that I've found is https://www.bernina.com/en-CA/Products-CA/BERNINA-products/Software-Designs/BERNINA-Embroidery-software/Advanced-Embroidery-Software/ArtLink-Seven . ArtLink 8 is also Windows 7 compatible. However, I haven't found any documentation on the supported sewing machines.
The driver issue also applies to the dongle. Try this site: https://www.bernina.com/he-IL/Support-IL/Software-he/Embroidery-Software/Dongle-Driver . However, since you have the Editor Lite v4, this dongle may not be supported under Windows 7. The dongle driver is not updated regularly. For some information about the software limitations, see https://www.bernina.com/he-IL/Support-IL/FAQ-he/Software-he/Can-I-update-my-BERNINA-embroidery-software-Editor .
I hope this helps.
(There is a patch for the v5 software to run properly under Windows 7. There isn't one for the Editor Lite v4 to the best of my knowledge.)
430 aurora
Probably too thick to feed without dislodging the bobbin case, causing the error message.
Bernina aurora 430 calibration problem
The complete manual is available at:
http://www.bernina.com/en-US/SupportData/BERNINA-Nah-und-Stickmaschinen/aurora/Manuals/032907-52-04_1103_a430_a440_a450_EN
A reset can be done as follows:
press the clr button. The altered stitches will be set to basic when you turn the machine off
Aurora 430 Bernina
Hi, possibly your feedogs are dropped and in the darning position and/or its thinking you want to embroider and there is NO hoop attached or entire embroidery unit plugged in. Check your feedog button below the handwheel on the bottom.
Rick
1helpful
Bernina Aurora 430 utomatic button hole
Take it to your local bernina dealer and have them calibrate the buttonhole foot along with the speed control.
1helpful
430 will not recognize wembroidery unit.
I am the person who posted the solution about too much stabilizer. Unfortunately that did not solve the problem in the long term. I spoke with the Bernina dealer and found out that the sewing machine needed to be recalibrated. I found out how to do this from my user manual and the problem appears to be solved for now... hope that works for you
Top Bernina Sewing Machines Experts
ZJ Limited
ZJ Limited
Jesse Walters
Jesse Walters
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
