Question about Prima CV1311 TV
Prima Television help me
Hi Tv is stuck on one chanel remote wont work and also remote. It wont shut off by pushing the shut off button only way it shuts off is by un plugging it.
  • Anonymous May 25, 2008
    While cleaning my prima tv I got a static charge and it immediately switched to channel three with a blue screen. The buttons on the tv will not work nor will the remote control. The only way to turn it off is to unplug it.
Theres a blak box with a code on my t.v
Posted on Jan 31, 2010
Why won't my samsung smart tv emote wont change chanel
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
  1. TV off
Within 3 feet of TV
PAIRING and RESET buttons:
Please rate if Helpful.
Good Luck !!
May 25, 2014 | Samsung TV Remote Control
Sanyo model # ds19310 16 jnch tv stuck on video chanel wont change to any other chanel volume works pat of menue works but the channel search and two other chanel menue controls are not available tv skips...
If you still have the Sanyo remote, you just need to press the INPUT button on the remote. The channel search and some other functions are disabled when the TV is in video/AV/game mode.
If you don't have the Sanyo remote, but you have a Universal remote which you use with the TV, look for a button labelled INPUT or SOURCE on this remote and try pressing it.
If you don't have any remote for this TV or you are using a universal remote which does not have an INPUT or SOURCE button, please reply to me from within this page for further assistance and let me know the brand and model number of any universal remote you are using. There is no option in the menu for doing this, but there a couple of methods which work on some TVs
Hope this helps.
Regards,
BElectric
Feb 05, 2011 | Sanyo DS19310 19" TV
3.4 IR Dish Network remote control codes for a Prima TV/DVD combo. I can't seem to find any codes that work for either.
I'msorry I did also attempt to locate a Prima remote code within DISH Network's database aswell but unfortunately I was unsuccessful and have found no remote codesfor the TV you have. However, we can still attempt to program the DISH Networkremote to the Prima television without a remote code, this would be done bycompleting a Power scan. If you decide you would like to program the DISHNetwork remote to your TV using the power scan, I have included instructionsbelow to further assist you. Withthe desired equipment on, press and hold the correct Mode button (In this casethe mode button will be "TV") until all the other mode button back lightsilluminate, then release. 1. Pressand release the Power button. 2. Pressthe Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, theequipment will power off. 3. Pressthe POUND (#) button. If the codeentered is valid for the remote, the mode light flashes three times.
After successfully completing the power scan to program the DISHNetwork remote to your T.V the remote should now control your TV. I hopethis helped! Please feel free to let me know if you have any other questions orneed additional help. -Kirstie DISHNetwork
Jan 30, 2011 | DISH Network IR Remote Control
I'm looking for the remote code for the PRIMA LC-20Y15 television in order to activate my remote control for my Bell Satellite system. Any ideas? Thanks
The remote codes are here.
I didnt see the Prima LC, but you can still problem with the instructions below.
If you tried all the codes provided for the manufacturer, try the following steps to find another code.
  1. Make sure the TV is on.
  2. Press and hold the TV button on the remote until the SAT, TV and VCR buttons light up.
  3. Let go of the TV button. The TV button should start to flash.
  4. Press the Power button on the remote control. The TV button will stay lit.
  5. Press the up arrow on the remote every second until the TV turns off.
  6. When the TV turns off, press the # button on the remote to lock the code. If the scan was successful, the TV light will flash 3 times.
Your remote should now be programmed to work with your TV.
Dec 21, 2010 | Televison & Video
Need help to program my new T.V. to my remote
hold down code until it stays lit, then press tv then keep hitting channel up or channel down (either one can be used, keep pressing channel button til tv changes channels when it does press enter, or ok if enter is not there, it may take awhile maybe a few channel pushes up to 200 and up times, you use this method when you don't know the code for your tv. Hope this helps.
Nov 30, 2009 | RCA D770 Remote Control
Remote quit working.....tv comes on and goes off by itself at various times
Sometimes Buttons on remote control "stick" underneath the faceplate. It's possible the on/off button is jammed. A lot of times when a button is jammed the other buttons fail to work.
Could also be the reason you needed to replace the batteries with a button being continously pushed will drain the battery life.
Push every button on the remote and kinda wiggle each button while pushing to possibly see if its stuck.
Hope this helps.
May 26, 2009 | Norcent Technologies PT-4291HD 42 in....
Imm stuck on the cbbc chanel on digital
Press the up channel button on your remote.
If this doesn't work then change the batteries or press the channel button on your TV
Jun 24, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Prima combo tv does not come on when the power button is pushed or even with the remote
check the fuse first then, resolder the power supply of your tv.
Jun 20, 2008 | Prima CV1311 TV
Can't get the remote to work
Try pressing the TV button on the Prima remote to make it work on the TV. It should work on the Prima Tv without new codes. Codes would be needed for your cable box.
Consider calling Prima at 866-447-7462 for the codes. They should have a website for the codes or email you the codes for free.
PS Please rate me if this helps.
Mar 30, 2008 | Televison & Video
Chanel button or sony kp-51ws510 51 in rear projection
the circuitry within the TV is where your problem is. thats why your remote wont work it either. Could just be he wire arent pluged in completely or you could have a bad resistor on the control panel PC board. Hope this helps. Let me know if I can assist you any further.
Jan 22, 2008 | Sony KP-51WS510 51" Rear Projection...
Televison & Video Logo
521 people viewed this question
Top Prima Televison & Video Experts
romy sibug
romy sibug
Jerry Greenberg
Jerry Greenberg
Are you a Prima Televison and Video Expert? Answer questions, earn points and help others
