Roper Model# RAS8333RQ4. It will fill up with water, but when it goes to agitate or spin, it makes a whirring noise like the engine is stuck. Is there anything that could bind or lock up? (aside from clothes which has been ruled out)
  • 5,911 Answers
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. That "whirring" noise is a common symptom. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
If you have any questions, please let me know. I hope this helps you.
Posted on Jul 11, 2009
Loud constant noise (metal on metal clicking / whirring / grinding) during spin cycle
renault laguna 2006 diesel. unlock code for radio... modell renrdw100-10 .
n874 security...
pls..
thanks
Nov 22, 2013 | Whirlpool Washing Machines
Will not spin loud noise
Need a full model #. Describe the noise; is it a banging, scraping, whirring, etc? Does it make the sound when it should be agitating and/or spinning? Has it run fine until this incedent?
Thanks.
Jan 07, 2013 | Washing Machines
Roper washing machine is not agitating. Makes a horrendous noise when supposed to be aggitating. No noise when filling with water.
In addation to the agitation does it make the same noise in spin??
If yes it makes that same noise in spin the problem is going to be a broken motor coupler. I have written this tip about a broken motor coupler it will show ya how to take apart the washer and replace the coupler. http://www1.fixya.com/support/r10293994-whirlpool_made_washer_not_agatating
GENE
Oct 10, 2011 | Roper RAS8445KQ Top Load Washer
Not spinning or rinsing?
After the machine fills the next step is to agitate. By agitate I mean the wash portion. The plastic fin in the middle of the tub rotates back and forth. So, after the washer fills, if the machine does not agitate, but stops dead, you have a broken lid switch. When I say stops dead, I mean no noise whatsoever. If the machine makes noise you have other problems.
If the machine fills, agitates, and then stops dead, the problem is still the lid switch. The next step would be describing the noise so I can more accurately give a suggestion. Problems include but are not limited to: broken couplers, malfunctioning water pumps, and/or defective motors or transmissions. These are the vast majority of the problems, and the others need no mention.
With a model number I can give a part number of the lid switch, and or other problematic parts. Also, I can give you an average price of the parts. With this information you could order it yourself and save money :) The model numbers are located under the lid of the washer. Not physically on the lid, but right under it. Get eye level with the top of the washer and you will see it ;)
May 28, 2010 | Roper RAX4233PQ Top Load Washer
Roper washer RAX4232PQO doesn't agitate or spin
It sounds like you may have a broken motor coupling. This is a common problem that usually occurs through normal wear and tear. Replacement couplers are more resilient and resist breaking much better. If the washer will fill, will not agitate or spin, but will still drain, these are the symptoms of a broken motor coupling. The accompanying noise of the motor engaging and a rattling/grinding sound is also a common symptom. This is a very simple and inexpensive repair. The following link explains step-by-step how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The part number is included in the link I provided. You can purchase a replacement on line at appliancepartspros.com for about $11.
NOTE: Roper is manufactured by Whirlpool and uses Whirlpool parts, so these instructions will apply.
Oct 04, 2009 | Roper RAX7244KQ Top Load Washer
Roper RAS7233KQ0 NO SPIN
chek the water elctrovalvles and replace it , this most be 1 solution another will the hyperstatic hose or sensor of load size
Mar 04, 2009 | Roper RAS8244KQ Top Load Washer
Model RAS7133pqo
If it agitates, you probably need a new gearcase. If not, check the coupling between the gearcase and motor. Hope this helps!
Feb 03, 2009 | Roper RAS8445KQ Top Load Washer
Roper Wash Machine Model # RAS8333RQ4
check the switch under the door , it could be damaged , check with a multimeter at OHMS setting , if there any reading then switch is OK , if not try to clean it up with tuner cleaner , you can purchased at RADIO SHACK.
Dec 17, 2008 | Roper RAS6233KQ Top Load Washer
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
