My Maytag washer will not spin the clothes. The washer will wash the clothes and the water will pump out but the spin cycle will not spin the clothes. It does began to make a squeeling noise after trying to spin.
  • 10,515 Answers
The noise was indeed coming from the water pump. To clean the pump on this top-loader you have to unplug it, pop the top open, and remove the front face of the cabinet to expose the motor and pump. Slip off the two metal clips hugging the pump to the motor. Place a towel under the motor before detaching the hoses - there's a plastic drip pan between the pump and motor to guide the water away from the motor. Unclamp the two hoses from the pump by squeezing their spring-clamps with pliers and sliding them further down the hose. Pull the hoses off by lifting the pump off its axle and pulling it out while wiggling the hoses loose. I found a small sock jammed in the pump - it must have fallen to the outside of the basket but inside the drum during the last spin cycle, and went down the drain hose. Check the pump for damage and replace if necessary. For future troubleshooting, remember that a clogged pump causes squealing, diminished spin speed, and slow drainage.
Any further information, let me know.
Thanks for using " Fixya " and have a nice day!!
Posted on Jul 11, 2009
My maytag washer does not spin fast enough to get the water out of the clothes. Please advise
Randall, the high speed spin failure can be caused by a number of issues. I would suggest starting the machine without any clothes in it. Once it has filled, make sure the door lock light is on and that the door is, in fact, locked. If the light is not on, or if the door is not actually locked, either the door lock assembly or the control panel is at fault.
If the light is on and the door is locked, stop the wash cycle and start a drain and spin cycle to see if all of the water is pumped out of the drum. All water should be pumped out within 10-15 seconds. If excess water is in the drum, the high speed spin will not start.
Mar 06, 2015 | Maytag Washing Machines
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Spin cycle not working properly. A little water (1 inch) is left and clothes are heavy with water. I tried the spin cycle repeatedly - water still at bottom of tub.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 10, 2011 | Maytag Centennial MTW5800TW Top Load...
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune TL clothes still dripping wet after full cycle
Pump out time of 40 seconds sounds good.
No ND error code and you spin up to 850RPM which is max for the machine.
You have no standing water in the wash basket.... I'm scratching my head.
Could you do a Spin Only cycle with that same wet wash load and set the SPIN for Max Extract. After you start the Spin Only cycle put the machine in Service Mode and watch the RPM range. This cycle sets the display to 12 minutes. Let’s see if the wash load remains wet and what max RPM is reached.
""Maybe the pump is not turning on during the spin cycle?"" You have no standing water in the wash basket correct? I feel the pump is turning on or you would have standing water in the wash basket and the pressure switch would have never indicated an empty condition (Low Level pressure switch contacts) to the Control Board. The Control Board would have stopped the wash cycle with a ND for no drain error code.
The pump in the spin cycle will turn on a number of times see if you hear turn on in a Spin Only cycle
I just ran a Spin Only light wash load with about 5 gallons of water in the wash basket. Timer went to 12 min. I toggled into Service Mode to watch wash basket RPM. At about the 5 Min mark (toggle in and out of Service Mode) the wash basket reached 850RPM then a few minutes later it stepped down to 830RPM to end of Spin Only Cycle. You don’t have a water valve stuck open or you would flood/over flow of the machine. Did you here the drain pump turn on several times during the Spin Only cycle?
Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag PAV2000AWW will not drain or spin in 2 of the 3 wash cycle
It won't drain
If your washer won't drain, check these:
It spins, but doesn't pump
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Nov 27, 2009 | Maytag Washing Machines
Spin cycle
it sounds like there is either an obstruction in the pump, or the load is getting off balance during the spin cycle. two things to try, fill the washer with no cloths in it, when it starts to agitate, stop the cycle and put it in drain/spin cycle. the water should be out in under a minute. its hard to see because the door locks, but you can hear a difference in the pump when its out, or after 60 seconds, press cancel and open the lid to check. if the waters out in that time, the pumps ok. then run it through the spin diagnostic with a load of cloths. make sure the cloths are wet, and a normal load you wash. this will check to see if the load is getting off balance, and shutting down during the spin cycle. let me know if you still have the problem. good luck, shane
Aug 23, 2009 | Maytag Neptune Washer
Not spinning to spin-dry clothes.
first check the motor bushes they are more than likely to of worn.
Jul 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag model# sav365zaww squeeks
check your pump the bearings in your pump
could be going out this will cause the water not to be pumped out properly and will also cause a squeek
Dec 29, 2008 | Maytag SAV365Z Top Load Washer
Washer does not remove water in final spin
If washer hums when it should spin, and the washer will not drain, you may have 2 issues.
First check that the drain pump, drain hose, and wall drain are free of debris.
The washer may not spin properly if the drain system is not operable.
Once you are sure the washer drain pump, drain lines, wall drain, and drain hose is okay, run a test wash.
If the washer hums but now drains, you fixed one issue.
If the washer still hums, you may have a bad belt, motor coupler, motor itself, etc...
Check parts for wear and replace as necessary.I pulled the drain impeller and found a sock from my little guy stuck in there. Fixed!
check all water outlets to make sure there is nothing blocking the pipes.
you could also go to this link it might help you out..... Washer does not remove water in final spin Google Search
Oct 24, 2017 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
