TV will not power on
Where is the fuse located at so I can check it.
    President:
  • 563 Answers
Any and all fuses are located inside the TV, however, the problem you're having is likely caused by more than a blown fuse. It sounds like you may have a problem with the power supply. Unfortunately, you'll have to have the set looked at by an experienced tech at a local repair shop to determine exactly what's wrong. Unless you have experience with television repair, you don't want to mess around inside of one.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need further assistance so that I can help you further.
Posted on Jul 11, 2009
Where are the fuses located on a 37 inch flatscreen magnovox?
The fuse can be located on the power supply board. To locate the power supply board, trace the TV wire back into the TV. The area where the TV wire is soldered inside the TV is the power supply board. There is fuse on the board. So this means you have to disassemble the TV....
Regards.
Walesarumi
Sep 28, 2011 | Televison & Video
No power to TV
First thing to do if your television have no power is check the power outlet,then the AC cord continuity.If the ac cord have power supply,check the fuse,maybe the fuse is busted.Its is located at the power supply.So try to remove and open the back cover of your TV and look the power supply and replace the fuse if busted.Replace same value of fuse.Try this procedure,hope it will help you.Thanks..
Aug 26, 2011 | Panasonic Televison & Video
I have a 46" Flat Screen TV. Model Number
First thing you do is to check the outlet if there is a power output the check the power cord and plug.If there 's a power in the power cord,Check the fuse of your television.The fuse is located at the power supply.You can see the power supply when you open the back cover of your television at the upper right side.Replace the fuse if busted with the same value of fuse.That's the step you can do first..Thanks..
Aug 25, 2011 | Televison & Video
Power won't come on
No power signal lights appear?If no power lights try to check the fuse inside your TV.remove the back cover to see the fuse location.It is located besides the power supply.check it if busted,then replace the same value of fuse.Unplug first before removing the cover to avoid electric shock.thanks!!
Jul 07, 2011 | iLO LCT32HA36 Television
Pushed the power button but the tv does not turn on
Hi.Please check the fuse of your television located inside the TV.Try to remove the back cover of your TV and find the fuse location.Its located at the back right near the power supply.Check it if is busted and replace the same valiue of fuse.Unplug the TV before removing the cover to avoid electric shock.tanks
Jul 05, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
My trueflat 32" toshiba tv
Hi.Your tevevion have no power.Try to check the fuse if busted.The fuse is located at the inner parts of your tv,try to remove the back cover of your tv and find the fuse near the power supply.
Jul 04, 2011 | RCA TruFlat 27F520T 27" TV
SAMSUNG LN52B610 TV TURNED OFF BY ITSELF. CANT TURN TV ON. NO RED LIGHT ON TV FOR POWER. OUTLET WAS CHECKED AND HAS POWER. CORD IS IN GOOD CONDITION. PLUGS FIR SNUG IN...
Hello.
If you have multimeter available you can actually check if voltage present at the end of your power cord first.
If it's OK than you have to remove back cover from your TV and locate power supply board. It's very easy - it should be next to the power cord receptacle. First look for capacitors that have bulged tops instead of flat ones. If you locate any - replace them and check if it's going to take care of problem.
Right next to receptacle connection is fuse located and you have to check if it's open. Replace it if needed. If new fuse got blown right away - you have short in power supply board. If fuse is OK - connect power cord and using multimeter try to figure out if 5V is supplied from Power supply board to the main board (the one that have all inputs attached to it). If 5V is present but power LED in front of the TV is still dead - you could have problem with main board.
Best regards.
Russ.
Aug 17, 2010 | Samsung LN52B610 52 in LCD TV
Power failure
Locate the fuse inside and check. If fuse is OK check the diodes etc.
Apr 01, 2010 | Sony FD Trinitron WEGA KV-SW29M50 29" TV
RCA 61 INCH REAR PROJECTION MODEL # P61929 PUSH
The first place to start is the outlet and check to be sure it has power. The next is to check / replace the main internal (to the tv) fuse - it's a 5A 250V GMA fuse (google image of GMA fuse). To find the fuse, unplug the set and remove the back cover of the TV - follow the power cord to where it enters - the fuse is located to the right and slightly ahead of where the power cord is attached to the board.
Nov 08, 2009 | Televison & Video
TV wont turn on
have you checked the fuses inside the set. The power outage could have surged just enough to blow the fuse. Dont forget to unplug it when you check the fuse.
Jan 21, 2008 | RCA P52937 52" Rear Projection Television
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
