Question about GE WBSR3140DW Top Load Washer
My washer machine will not drain water .the model is WJSR2070
  • 6,784 Answers
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line.....
Posted on Aug 08, 2009
White magic 1 2 3 700 h 6th sense problem after wash water not draining from machine
Washer will not drain:
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it
Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed.
If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuityMy advice is free cuz God is good!
Fix Washing Machine That Won Drain Washer Not Draining Water
Jan 03, 2017 | Washing Machines
Fahe1011mwo Frigidaire washer won't drain
Read more:
Dec 29, 2016 | Frigidaire Washing Machines
Maytag neptune model number mah5500bww washer not draining
Dec 26, 2016 | Maytag Washing Machines
How would I drain remaining water from washing machine?
Jan 26, 2016 | Washing Machines
Washing machine won't drain.. What do I do
Jun 17, 2015 | Washing Machines
L G Top loader washing machine model # WT - R 801. Has error code LE. will not drain water or go to wash cycle.
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Apr 15, 2015 | Washing Machines
Water coming out from under washer
What is the complete model number of your unit?
Nov 23, 2012 | Washing Machines
My washer dryer ventless combo spins but wont drain all the water or dry. the lint trap is empty and the dryer is working but the water is not fully draining the last amount out of the machine
Mar 15, 2011 | Equator EZ 3710 CEE / W Ventless...
Washer makes straining noise when draining water from tub while spinning?
my admiral washer machine model AAV7000AWW makes a noise only when draining/spining water, is no water spill at all. Thanks
May 21, 2010 | Washing Machines
Washing Machine does not drain all the water
Hello nsukiwa.
Welcome,
What is the model number?????????????????????
As I am working blindly for you!
Here are some ideas, until I have the model number.
You said, your washer is a Hotpoint type. When emptying the water it never finishes all the water. You have to throw the drain pipe on the floor to drain it dry.
I'm searching for answers to your problem with these questions!!
1. How long is the drain pipe and does it have to pump up higher than the machine to reach the drain?
As if it is in the basement and the drain pipe above it?
In this case you would need an external pump with some machines!
2. Is the water visible in the bottom of the machine when the load is done?
Or do you just detect some water left in the hose?
There usually is some water left in the hose, but it is not supposed to be visable in the machines tub.
3. I have a Speed Queen washer because this machine can pump the water up above the washer for 7 feet straight up to the drain above!
Most machines are not capable to do this!
I am awaiting your answersHuuum
Oct 16, 2008 | Electrolux EW1000i Front Load Washer
GE WBSR3140DW Top Load Washer Logo
241 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
