Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Brushes won't turn on my bissel proheat 2
Brushes won't turn
SOURCE: Anyone know why my Bissell Proheat 2X Turbo Model
If the Brushes don't rotate, & you have two brushes; 1). Turn unit on side. ( Make sure unit is up-pluged) 2). Rotate the front brush roller, if the second roller moves at same time, 3). Locate a small ribbed belt that goes from the further back roller, to a small ribbed pully. (Gates belt #177-3m5) ( on side under a clear cover) The belt may not be broken, but may have carpet fuzz / lint covering the belt ribs, causing the belt to slip. If that belt is OK and you find that the small pully doesn't turn the belt/rollers, the problem is with a small internal direct drive motor, that drives the brush rollers. At this point return the unit, as Bissell has a design defect & is using cheap parts.
Posted on Feb 27, 2010
reddevil6
  • 1673 Answers
SOURCE: bissell proheat 9200
The brush roll motor is most likely bad (part #2036757). You will have to take it aprt and check it.
Posted on Mar 06, 2008
  • 184 Answers
SOURCE: Brushes aren't turning on Bissell Proheat 2X and
New or old,flip the vacumm over,and remove the long hair and debris from the roller brushes. If they don't spin after removing any debris,the
belt,that turns the brushes has come off,or the motor is bad. You wil
have to take the bottom section apart,to see what's going on,then.
Good luck.
Posted on Apr 01, 2010
heatman101
  • 43501 Answers
SOURCE: Bissell ProHeat, Brush won't turn, belt fine.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
dh
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: cannot figure out how to install brush belt on a bissell proheat
heatman101
twywt
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
I am trying too use my Bissell Proheat 2X, but the brushes will not rotate. What is wrong?
1. Can you hear the electric motor in the base unit going?
2. You may have a broken drive belt.
Type the following link into your browser. It will bring up the user guide to the Model 9500p upright ProHeat 2x.
Sep 21, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
Brushes not rotating
heatman101
45wtw
Jun 21, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
The brushes on my Bissell Proheat 2x shampooer won't turn.
You need to replace the belts on the roller brush. Here are the belts you need:
Bissell Proheat 2X Belts
May 24, 2010 | Bissell Lift-Off(R) Revolution(R) Turbo...
heatman101
dh
Jul 16, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
MY BISSELL PROHEAT WONT SUCTION
heatman101
ffuutr
Jan 28, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat 2x
Check the brush motor, I have had to replace of few of them. If the brushes aren't turning, this could be the problem.
Apr 18, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
200 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
