Question about Malber WD1000 Front Load Washer/Dryer
Whirlpool washer front loader model LHW0050PQ
Spin cycle just rolls slowly one direction, then switches to the other direction but won't get up to full speed spin no matter what the setting.
This behaviour started when during the last normal spin the drum load was heavily unbalanced and spun violently then stopped and did the slow rolling. Since then the washer gets stuck for ever on the slow spin cycle. The belt is OK.. Is there any spin protection to be reset? No suspect noises. The rest of the washing cycle is OK.
    Problem Solver:
  • 13 Answers
This is not a Malber machine but the following fix has worked for the Malber washer. Try unplugging the machine for at least 2 minutes. Do not just turn it off as there is still current going to the machine .This should clear the computer. If this does not work, the imbalance may have overloaded the circuit board requiring replacement.
Posted on Jan 07, 2008
Whirlpool top loader washer will not spin
Could be one of several different things depending on the age and model. If its less than 10 years old and is a top load washer its probably a motor coupling (connects the motor to the transmission kinda like a belt) or lid switch. If the water is draining out but the washer is not spinning its probably the motor coupling. If it still has water in it and won't spin, its probably the lid switch. If your washer is a front loader there could be several things going on. Hope that helps.
Aug 29, 2011 | Whirlpool Washing Machines
Whirlpool Front Load Washer (LHW0050PQ) not spinning
Use a quarter inch nut driver to remove the bottom panel. A tech sheet should be under there that will give diagnostics. Open the pump filter and check for objects.616c06e.jpgea4423e.jpgfb90284.jpg
Jul 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Loud clanking noise during spin cycle. Will not
If it is a front loader, then remove the rear panel, remove the belt, and soin drum by hand, if it feels rough, or is noisy and rumbling, then the main drum bearings have failed.
This is a major repair.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
How to change the belt in my whirlpool washing
It's probably the washer transmission. Belts aren't common anymore & besides it wouldn't work at all if there was a belt broken.
Jun 18, 2009 | Whirlpool Washing Machines
Basically,the machine you have is garbage! - I have one also, It is less than one year old and the repair folks have been out 5 times. It doesn't spin either!
I'd call this one a lemon!
Apr 14, 2008 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool lhw0050pq washer will not spin
Possible your belt is loose; you have to unscrew the back after disconnecting electrical connection from wall socket. If the belt "gives" more than half an inch, you have to loosen the motor bolts and push motor upwards, then tighten the bolts very well. Try spin only to check, before closing the behind. It shd spin very fast.
Apr 25, 2007 | Whirlpool LHW0050PQ Front Load Washer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
229 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
