Question about HP Officejet 6310 All-In-One InkJet Printer
Envelopes won't feed into my hp 6310 all in one. What can I do?
  • Marc Laprise
    Marc Laprise May 11, 2010
    Are you putting the evolopes in the right place in the feeder tray? Or it worked before now it don't?
  • 85 Answers
Hello db,
Try this...Place the envelope to the right side of the feeder. Position the envelope with the flap facing up and to the left. I use Microsoft Office Word software for feeding and printing envelopes with good results. You can also go to the HP website and download their envelope printing software for free.
Hope this is helpful for you. If it is, please leave positive feedback for me. Good luck! NormanZ
Posted on Jul 14, 2009
This is not a solution but the same problem. My HP 6310 was printing envelopes fine then now suddenly jams. What to do?
Posted on Feb 18, 2012
3 Suggested Answers
  • 21 Answers
SOURCE: HP 4L Envelope Feed Problem
check the internal roller ( central ) easy to remove . clean with alcohol's dry put it back ... (robber couvred)
Posted on Mar 13, 2008
Salim Baig
  • 283 Answers
SOURCE: my hp J4680 won't feed
Hi
The envelopes are standard in size hence do not use any odd sizes. And also do remember that you make the required alignment and also the feeding directions and positions. If you print in Landscape then the paper is too short for the printer to pick. Hence use Portrait so your printer can sense the presence of the envelope
Posted on Jul 16, 2011
What is thbest hp printer for printing envelopes.
The best way to deal with envelopes is to either get a label printer like a Brother, or get laser safe window envelopes. Envelopes cause many problems and if you are going to print a large number of them you will wear out the fuser prematurely because the outer edges of the fuser will overheat feeding the narrower paper.
Oct 19, 2016 | HP Office Equipment & Supplies
PRINT RUBS OFF
When printing envelopes ensure you set paper/media type to Envelopes, and feed via tray 1/bypass . Paper type setting sets correct fuser temp, the fuser is the hot bit at the rear that "melts" the image into the paper.
If paper type is set correctly then I recommend you change the fuser unit.
Ensure envelopes are standard type. ie you are printing on paper envelopes
Feb 11, 2008 | HP LaserJet 5p Printer
Print envelopes
Are you using the tray 1 manual feed for the envelopes? If it was working for you before but now has trouble feeding from that tray you are probably going to need a new PU roller and sep pad. You can try and clean the roller with a lint free cloth and use isopropyl alcohol.
Sep 02, 2014 | HP P2035N LaserJet Monochrome Printer
I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
My hp J4680 won't feed envelopes, the envelopes goes part of the way in and then fails to print
Hi
Jul 16, 2011 | HP J4680 Office Jet All-In-One Printer
HP 6280 PRINTER WHERE DO YOU PUT THE ENVELOPES INTO THE PRINTER
I asked the same thing of HP Technical Support. The user guide isn't very helpful. Envelopes and manual paper feeding go into the gray tray. The blue tray is only for photos.
Mar 31, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printing envelopes 4" x 91/2"
when you print envelopes you will have to select the paper size in the print options. There should be a pull down menu with every paper size and envelope size. Select the appropriate one, and be sure the envelopes are placed the right way when you feed them in. Most home printers work best when you manually feed the envelopes in. Its a tricky process, and you may have a few jams.
Feb 10, 2009 | HP DeskJet 9800 InkJet Printer
Envelope printing
I have an older, but similar, 5510 model with the same problem. A partial solution that works about 75% of the time is to tuck the envelope flap inside the envelope and give the end of the envelope that is to feed into the machine a slight curve by gentlly bending it on both sides. Then make sure there are only a few sheets of paper in the paper tray (less than 1/8" thick stack). Position the envelope so it is only about 1/2" from the end of the paper in the tray so the feed rollers have to transport it into the machine. I also have to set the margin for the return address in Word to be 1" from the edge of the paper so it prints in proper position, but this may be a problem with my Word 2000.
Feb 07, 2009 | HP Officejet 6310 All-In-One InkJet...
Printing Birthday Card Envelopes approx 4.75 x 5
There should be brackets to hold the paper in place. Most printers suggest that you feed the envelopes in landscape instead of portrait.
Dec 17, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Envelopes
Follow this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu03053&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Sep 28, 2007 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 6310 All-In-One InkJet Printer Logo
648 people viewed this question
Clive
Clive
