Expert
- Posted on Jun 25, 2015
Re: 1989 dodge ram 50 2.0 engine
Fuel pump
REMOVAL
- Disconnect the battery ground cable.
- Disconnect the fuel inlet, outlet and return hoses at fuel pump.
- Remove the two fuel pump mounting bolts, and remove the fuel pump.
- Remove the fuel pump gaskets and insulator.
Check for leakage, if there is oil or fuel leaking from the breather hole, oil seal or diaphragm of fuel pump, the pump is defective. Replace fuel pump as an assembly.
INSTALLATION
- Turn the crankshaft so the No. 1 cylinder is at top dead center on the compression stroke. NOTE : This is to minimize cam lift for ease of installation.
- Insert the push rod into the cylinder head.
- Install the new gasket and insulator, install the fuel pump.
- Tighten the bolts firmly.
- Connect the fuel hoses to the fuel pump ******* and tighten the hose clamps.
- START the engine.
- Check for fuel or oil leaks.
