Question about Microwave Ovens
Our fairly new LG microwave has stopped heating. Serial n. LMV164ODB1 Is there a fuse somewhere? We had a power surge could that had caused the problem? Any other suggestions?
  • 456 Answers
The best bet , due to it being a power surge, replace the high voltage capacitor, the high voltage fuse and the magnatron assy. good luck.
Posted on Jul 12, 2009
LG under cabinet microwave (LMV2073ST) overheated. Now no power to unit.
There may be a fuse inside.
Always put a microwave back together to test it. A mobile telephone in the vicinity will also check a microwave for leaks.
Feb 14, 2015 | LG LMV2073ST Stainless Steel 1100 Watts...
Why did my micro stop working?
I guess the main plug fuse does not blow for the same reason it does not blow and you can wreck a PC, although not certain why that is. I have a feeling from past work on a Panasonic that there is an internal fuse as well. This may have blown with the power surge.
Jul 07, 2014 | Panasonic Nn-sn797s Countertop Microwave...
Panasonic microwave problem help needed
Dan, That unit has an inverter, that is the power source for the part that puts out the Microwave energy called the Magnetron. The inverters are expensive and I stopped doing warranty work for Panasonic beacuse of them. Some pencil pusher somewhere though it was a great idea to replace 3 common fairly inexpensive parts. with that dang inverter. Microwaves have come down a lot in cost, I would buy a new one without an inverter. Sorry, wish I had better suggestions, I DO NOT LIKE THEM. LOL Sorry! Panasonic and their distributors are always out of them and there so expensive no one wants to stock them. I have had new ones sent to me that were already bad.
Aug 20, 2017 | Microwave Ovens
Hi there, I have a LG model: LMV1640DW1 microwave oven. Everything seems to be ok, but does not heat my food. The microwave is fairly new (feb 2008)
Possibly high voltage fuse or diode.If it is an inverter model may be circuit board problem.Not advisable to try and fix yourself very high voltage build up could still be present, contact your local repairer.
Apr 19, 2011 | LG Microwave Ovens
My LG LRMP1270ST microwave oven stopped working in the morning. It just flat died when I put 2:00 minutes on the timer and pressed start I heard the pop/breaking sound. So immediately I stopped the...
The main fuse has blown in the microwave, you also have secondary problem that sounds like the magnetron has failed, but there are two other parts to consider, the high voltage capacitor and diode work in conjunction with the magnetron to heat the food. The repairs could run as high as a new microwave oven.
Feb 14, 2011 | LG Microwave Ovens
We had a power surge in after power went out microwave not heat up anymore
It may have killed the processor if it is a fairly modern one. Here's a couple of ideas.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Dec 15, 2010 | KitchenAid Microwave Ovens
No display, no power on microwave
fuse is a easy fix, remove the cover, the fuse is located on the board. Most times the fuse is a indication of a bigger problem, sometimes a new fuse will fix if a power surge or metal in the oven caused the problem.
let me know what you find
Apr 07, 2009 | Microwave Ovens
GEJE2160 Stop Working
It probably blew the main power fuse in side the oven. This may have happen because of a failure in the microwave or a line voltage surge or what ever. Repalce the fuse and see if it work. be sure to unplug it before doing this, If this does not fix it then you have a failure in the oven some were.
good luck
May 16, 2008 | GE JVM1850 1000 Watts Microwave Oven
Cut out during heating
Possible causes include a blown fuse or high voltage diode. A bad magnetron or power transformer are also possible. I recommend taking the oven to a repair facility, or scrapping it & getting a new one. Do not attempt to repair this yourself, as microwave ovens have voltages present inside which are INSTANTLY LETHAL, & there are no user servicable parts inside.
Jul 16, 2007 | Belling BIM60 Microwave Oven
Microwave Ovens Logo
144 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
