I have taken the agitator out, cleaned all the accumulated hair, fur, lint etc off and it is a little bit better. I have washed the inside with vinegar, bleach and ran it empty all to no avail. If I leave the lid closed the next time I open it I smell the odor again. Where can the smell be coming from and how do I get to it?
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle. 1.Remove all items from the washer. 2.Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage. 3.Close the washer door and dispenser drawer. 4.Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes 5.Press Start and allow cycle to complete. 6.If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle. 7.After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior. 8.Repeat the cleaning procedure monthly. To maintain the washer freshness: 1.Use only HE High Efficiency detergent. 2.Leave the door open after each cycle to for better ventilation and drying of the washer interior. 3.Use warm / hot water in your machine unless the fabric you are washing requires cold. 4.Use the correct amount of fabric softener. 5.If your laundry room is damp, use a dehumidifier. 6.Clean the door seal of visible residue.
Was this helpful?
Yes
No
Popular Solutions for GE WHRE5260E Top Load Washer
we have a GE model #WHRE5260E1WW that stops in mid cycle and must be started with the push start/...
(More)
we have a GE model #WHRE5260E1WW that stops in mid cycle and must be started with the push start/ stop and pause switch. This may or may not happen several times during the course of running a single load? We haven't been able to isolate a series of circumstances that would cause this to happen. However, by accident ...the washer lid slip from my hand while filling and did cause the washer to shut off, just after all the phase lights flashed on, then went out as the washer stopped, as if the vibration cause it to stop, perhaps because of loose a connection! After carefully closing the lid, I tapped on the panel face, not on the cycle control knob itself, but on the metal, on both side! Starting out with light taps with my finger tips only and gradually increasing the strength of the taps I was able to get the"cycle light" to flash and then go out! I'm not sure what that proves, but it seems to me that just by tapping at that area shouldn't cause those results. The control board is a printed circuit with only couple of wiring terminal connectors, male /female type, which all appeared to be tightly plugged together, as well as the remaining spade type single wire connections. Now unless there is a hairline crack in the printed circuit board that I didn't or couldn't see, a board component...I give up! I will say that I'm relieved to read that others have had the same or a similar sounding problems!!! problems
GM whdrr418e1ww need to remove top. I don't see where it attaches. It sounds like a hose is...
(More)
GM whdrr418e1ww need to remove top. I don't see where it attaches. It sounds like a hose is hitting the outside of the drum when it agitates.
