Question about LG Refrigerators
I have a GR-L207CLQA. I have ice building up behind the vegetable drwers. As a result of that I have water leaking ouside the fridge from the front door. I suspect a leak. What can I do?
SOURCE: Fridge not cold enough and build up of ice at back of fridge
We had the same problem and were told that gas was not circulating properly. We had it topped up, but it broke a week later. It had to be scrapped.
Posted on Mar 30, 2008
  • 108 Answers
SOURCE: Refrigerator freezing up and fan catching
From your information Bill it seems the defrost system has failed. There are several componants that could cause this. First check the defrost heater which is located on the evaporator. You will need to pull the plug and let the ice melt completely first. Store your perishables elsewhere.
With an ohmmeter, check for continuity across the defrost heater. With all due respect, if this is confusing you need to call a service tech. If you have continuity across the heater, check the defrost thermostat which is a round disc fastened to the evaporator.
Finally, look for the defrost relay. It should be found somewhere on the lower rear of the refrigerator. Check for power to the relay, and on the outlet side. A wiring diagram located on the back of the unit will help you find the correct wires. All of these parts should be available from your local refrigerator parts supply, or check with Samsung online to order. Be advised Bill that this is not a simple repair, but if you have some electrical understanding, you can do it.
Ray
Posted on Nov 16, 2008
  • 56 Answers
SOURCE: Ice behind the high humidity compartment
You have clogged train which has frozen over. There is a factory kit to add a heater. You firrst might want to try and defrost the tube using warm water after your remove the ice. You want to make sure that water will flow down that trough and passed the tube. THe watere goes to a drain pan below.
Posted on Dec 02, 2008
  • 399 Answers
SOURCE: the freezer has ice build up on vents
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
also click the links below for more help
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Posted on Dec 06, 2008
david04928
  • 102 Answers
SOURCE: Build up of ice on bottom of LG fridge freezer
Is it supposed to be self defrost? If so then either underneath the freezer needs to be cleaned. coils if dirty will cause freezer not to work well. I that doesn't help you might have a freon leak which would make it under charged and would ice up like that.
Posted on Mar 15, 2009
Kenmore 795 leaking water behind ice maker
I would first check the hose that brings the water from the pipes in the house up into the icemaker make sure that's not leaking. Then I would check all of your connections, Making sure they are good and tight and that there's no holes either in the copper line or the poly plastic line. If all of that checks out fine and you have no leaks there then I would investigate the icemaker.
May 27, 2018 | Kenmore Refrigerators
I have a bottom freezer model # RB215ABBP/XAA with ice behind and inside the right-side vegetable drawer; some vegetables froze. Why?
Samsung has had this issue for a long time now. The problem is the drain in the refrigerator is clogged and leaking inside. If you remove the drawers and look back then you will probably see a rusty line where the water has been leaking and you will see water under the bottom long deli drawer.
If it has been leaking for a long time then it is recommended to replace the evap cover in the fridge section as the foam gets waterlogged and will cause future issues. If it just started the you should be ok.
There is a new drain kit part# DA82-01415A that will solve this issue.
The fridge should be defrosted for 24 hours prior so you can get the evap cover off without damage from the ice (unplugged and doors open for a full 24 hours. Longer times may be needed if this has been happening for longer then 2 weeks.)
Feb 11, 2018 | Refrigerators
Freezer won't freeze and fridge side freezing vegetables
In the back there is a radiator and it is frozen solid, you have to deice it, unplug the fridge and take the cover off and remove the ice build up, hair dryer should do the trick, or leave it unplugged for few hours.
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Dec 08, 2017 | Samsung RS2630WW Side by Side Refrigerator
Samsung RSH1JBBP Fridge Freezer is intermittently leaking small amounts of water from inside the fridge. It pools at the front right caster. Ice and water dispenser used occasionally. Not sure if...
I have a different fridge but had the same problem in the same area last year. Have you taken the front grill off the bottom and cleaned/vacuumed under the fridge at all? The dust build up there and behind the fridge panel builds up large enough for the fridge to not be able to cool itself causing condensation/drippage of this type. Reminder warning.. be sure to shut all power off before vacuuming out behind the back panel of the f fridge, that's where the fan turns. Hope this fixes the problem for you as it did for me!
Mar 27, 2013 | Refrigerators
Water building up at back of fridge
at the rear of fridge a drain channel with a red plastic tab will probably be blocked try a pipe cleaner . mike
Feb 17, 2013 | Refrigerators
GLRT216TAW2 Model Number. Water under vegetable drawers, No other water leaking. Back is dry, Do i need a repair man or new refrig which is only 10 yrs old.
Its the defrost problem.In your unit the defrost cycle is not running on time.This is the procedure of the unit.--- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to fridge passes from the section, in that section the damper is located.In your case the freezer gets cold, after that defrost cycle has to start, but in your case the defrost cycle is not starting on time so over ice gets internally build and when defrost cycle starts, this ice melts and this gets leaks in the vegetable and under vegetable drawer.-------- Get the defrost timer, and defrost assembly parts checked and repaired by the technician.Repairing will solve the problem.You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
May 04, 2011 | Frigidaire GLRT216TA Top Freezer...
Hi I have a Hoover Contour Fridge Freezer and recently moved this and now it is leaking. It looks as the level of fridge in on slope. How do you adjust legs to make this level and does this cause leaking?...
Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
NOTE-(This may be a leveling issue as well)
It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
Jan 10, 2010 | Refrigerators
LEAKS WATER UNDER FRONT OF FRIDGE
turn off the water to the icemaker under the sink or behind the refrigerator, if the leak stops, you probably need to change the valve, if it doesn't stop, it is probably a clogged defrost drain which will be evident by ice build up in the bottom of the freezer
Nov 01, 2009 | General Electric Profile PCF23MGW Side by...
Leaking water on the front corner of the freezer side. We have turned off the water to the icemaker and have turned off the icemaker. Still leaking, not fast, but each day I clean up a puddle.
That is from your defrost drain either being clogged with food, or covered with ice. Behind the back wall in the freezer is a drain that empties underneath the fridge. If that drain gets blocked or froze over then the water will dump into the floor of the freezer and out the door gasket. Look in your freezer floor for ice build up. If you don't see anything like that or if you think the water is coming from underneath the fridge, then it is your condensate pan underneath. They crack sometimes.
Sep 06, 2009 | Frigidaire Refrigerators
Water leaking inside of refrigerator from freezer
IT SEEMS LIKE YOU HAVE A CLOGGED DRAIN . CHECK YOUR CONDECER COILS BEHIND KICK PLATE .. AFTER THAT YOU CAN UNPLUG FRIDGE FOR 24 HRS WITH DOORS OPEN AND SOULD DEFROST ENOUGH TO CLEAR DRAIN . IF NOT . DEPENDING ON MODEL YOU SOULD BE ABLE TO GET THROUGH DRAIN THROUGH MOST FREEZERS .
Feb 03, 2009 | Kenmore Refrigerators
Refrigerators Logo
60 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
deecee73
Level 1 Expert
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
