Question about Craftsman Nailer Kit, Palm Air Driver
Nailer drives one nail but driver pin doesn,t retract back into nailer head
  • 256 Answers
Remove the air hose and open the nailer head section. Look for a foreign object in this are that could be jamming the drive pin. Also, make sure you are using the right size nails.
Posted on Jul 11, 2009
Drive pin does not retract
Easy to fix. Remove the head and pull out the cylinder. Look for black band around lower part of cylinder. This band (check band)should be placed around series of small holes. Replace if broken with any rubber that will hold up in oil or use a bunch of orings to fill space. Good luck.
Dec 14, 2013 | Porter Cable Air Tools & Compressors
I have a porter cable roofing nailer model # RN175 that does not advance the nails everytime what causes this?
Some causes, in order of probability:
Roofing nailers get a lot of tar build up on them, especially around the nose safety and nail feed pawl area. Cleaning off this buildup will usually take care of most problems with roofing nailers.
On the side of the gun away from the side you load the nails on there is a small cylinder with a piston inside that attaches to the feeder pawl. If air isn't getting to the piston or the piston's o-ring or spring is damaged, it won't cycle properly to advance the nails.
If the driver doesn't retract fully, the next nail won't be able to advance properly for the next shot. This can be caused by o-rings in the head that are worn or out of their proper place.
Oct 06, 2012 | Air Tools & Compressors
Nail gun will not fire the nail. Compressor works fine. Hammer doesn't retract enough to hit nail? Cause, solution?
could be a jammed nail in the magazine nose area, bent driver blade or problem with the o ring being worn.
Jun 06, 2011 | Hitachi NR90AD 3 - 1/2'' Clipped Head...
I have a senco framepro 600 clipped head nailer. Nails are only driven 2/3 of the way down. This occurs about 30 percent of the time. The portruding nail will be bent over against the wood. Air pressure...
The Senco FP600 is an older model gun, if it has been getting reguar use check the driver. After a lot of nails the tips tend to get rounded off towards the back side and if the nail hits some dense wood or a knot the head will slip off before it can be driven home. Replace the driver if so, trying to grind the end square will only result in problems with the guide when the driver retracts into the head.
Oct 25, 2010 | Senco SCN56 Medium Coil Nailer, Switchable...
I have a FC350A FRAMING NAILER, IT IS IN THE
check to make sure that there is not a nail jam , if the driver will not retract then the gun will not cycle . if no nail jam then replace the inner trigger
Feb 02, 2010 | Air Tools & Compressors
I have an FR350 PC nailer and I have a nail jamed in the noise piece between the housing and the driver. Do you have a suggestion?
Remove with a pair of plyers. If that does not work use a nail punch and drive the drive pin back into the gun until the nail comes free.
Feb 01, 2010 | Porter Cable Cable No. FC350A Clipped Head...
Drive pin will not retract
Return spring is week and the chamber may need more lubrication.
Oct 07, 2009 | Craftsman Nailer Kit, Palm Air Driver
The Senco SFN-1 gun will drive one nail and then not retract
sounds like time for a rebuild i do this once a year on all of my guns i buy a seal kit and replace them at that time and oil the interior oparts and check for worn or broken parts
Sep 03, 2009 | Senco Tools & Hardware - Others
After each shot the nail gun jams
hi visit your supplier and ask for a overhaul kit once fitted your tool will be licke new
best of look ian
Mar 25, 2009 | Senco FP620 Framepro 602 2" - 3 - 1/2"...
Craftsman Nailer Kit, Palm Air Driver Logo
343 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Craig Butler
Craig Butler
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
