Question about Euro-Pro S3325 Handheld Steam Vacuum
The motor is shot on my shark XSH035. can I get the motor replaced - as I prefer the attachable, flexible hose feature for cleaning cornors & creavices and the newer hand-held models do not provide this option.
  • 19,396 Answers
The motor is available from manufacturer.
The manufacturer website is currently not working, here is the website:Sharkvac :: Parts Search.
Try back in a couple of days to see if they have fixed the website.
Euro pro can also be contacted in the US at +1 514 842 8691, Fax: +1 123 123 1234 .
Posted on Jul 20, 2009
  • 3,037 Answers
Well, they don't make these anymore and so don't make the motors anymore. You may be able to find a used one somewhere, check ebay and craigslist daily but your only other hope is if a shop will try to repair the existing motor but I doubt it will be worth it as it will cost a lot to fix. Sorry for the bad news.
Benjamin
Posted on Jul 11, 2009
Shark professional nv355 wont turn on
could be the motor thermostat. Make sure the unit is clean. No dust build up in the filters etc. Then here are the motor reset steps.
Motor Thermostat needs resetting
In order to reset the Motor Thermostat:
  1. Move the Power Button to the "O-Off" position
  2. Unplug the vacuum
  3. Check for a clogged hose or filter; unclog the hose and replace the filter
  4. Wait 45 minutes for the vacuum to cool; then plug the vacuum
  5. Turn the power switch to the "I-On" position to start the vacuum
  6. If the vacuum still does not start, contact Customer Service at 1-800-798-7398
Jan 10, 2018 | Shark Vacuums
Shark rocket ultra light
Hello, this is Ava with Think Crucial.
Your Shark vacuum is equipped with a motor protective thermostat. If for some reason your vacuum overheats, the thermostat will automatically turn the unit off. Should this occur, you would need to restart the motor thermostat. Turn off your unit and unplug the vacuum from the power. Clean the filters and dust cup filters. Check for blockages in hose, accessories and inlet openings. Then allow the unit to cool for a minimum of 45 minutes before plugging it back and turning it on.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=shark
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Oct 17, 2016 | Shark Rocket Ultra-Light Upright Vacuum...
I think I may have a plugged hose. How do I take the handle off from the head to get to the hose?
Hi, it's Allie from Crucial Vacuum!
Your Shark Navigator Freestyle Cordless unit has a flexible air hose located on the floor base of your unit, which allows the air flow and picked up dust to travel from the floor through to the canister.
Accumulated hair strands and debris may cause this hose to be clogged, the dustcup inlet to be blocked or the brushroll to not run properly. Start with turning off your vacuum. Press the release button on the back of your unit's main body and remove the motorized brush. To reach and clear the air hose, flip back the connector to straighten the air passage and remove all debris or blockage found.
You can purchase direct your replacement filters from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/shark.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Oct 05, 2014 | Shark Navigator Freestyle Stick Vacuum -...
Why do I have no suction from our EP754C vacuum? Turns on but no suction?
Hi, please check the hose attachment you are using, sometimes tissue paper or fluff can cause the hose to block. You will have to remove any obstruction. Another test will be to check the area where the hose attaches to the vacuum, switch on without hose and use a piece of paper to see if there is suction in this area, if no suction then the problem could be that the inner filter housing the motor needs cleaning. Best of luck.
Jul 23, 2014 | Euro-Pro Shark EP754C Belt 2pk
Shark transformer vac model ep602 will not suction from the floor brush, but will suction from the flexible hose. Dust cup and filters are clean. Do I need to replace the floor brush? Unit was purchased...
Has the floor brush ever worked for you? I thought it was broken at first too. The hose has to be inserted in the appropriate hole in the side of the machine. The hose is where all the suction comes from, when you put it in the side hole it will provide suction for the floor brush.
Oct 11, 2010 | Vacuums
My shark steam mop heats up but won't steam. help
Problem: mineral dleposits. Just fixed mine.... DO THIS OUTDOORS. Add 1/2 c CLR to the tank, let sit for an hour, turn on, allow to heat and pump. May have to refill with CLR and repeat. Be persistent, and eventually you'll blow out a wad of dissovled minerals followed, happily, by billows of steam. Again, do this outdoors and keep the mop pointed away from people, plants and things. (I aimed mine into a cardboard box.) Follow up with a couple of tanks of water and pump until empty to clean out any residual CLR and loosened deposits. (I continued to get some black precipitate through the first water cleaning.) I will add that I began this process first with white vinegar, then with Lime Away..no luck put perhaps I was not sufficiently persistent. Or perhaps it was the sequence of attempts. (Also, do not take off the mop head...the part to which you attach the pads...it's tough to get off, does not allow access to parts that need cleaning (thought it would, not not so), and practically impossible to get back on.)
Alternatively, call Shark...they'll offer to repair for $18 plus $10+/- shipping, or may offer you a new one at "preferred customer" rate of $39.95 plus shipping. Good luck, and please remember to try the CLR outside.
Jan 10, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Steam mop won't steam
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
zsd
Nov 16, 2008 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Where do I find replacement parts to my SC-505?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=83390&thid=752335
Posted by deh127 on Jul 07, 2008
My dog ate thought the hose coming right from the steamer. I need to get a new hose and I never got the attachment that cleans the floor where can I get that? I only got the hose and then attachments that would clean a grill.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best place to get the added attachments for the Euro-Pro Shark SC-505 Handheld Steam Vacuum is to contact the Shark / Fantom factory manufacturer of which I will list below and this is a specialty vacuum and most local vacuum cleaner dealers do not have the parts but can order them for you if they are connected with Shark / Fantom. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sharkvac.com/ Customer Tech Support 1-800-798-7398
These are the other brands that use the same tech support line
Shark / Euro-Pro / Infinity / Bravetti / and Fantom
Hours are Monday thru Saturday from 9:00 AM to 6:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 07, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Euro-Pro S3325 Handheld Steam Vacuum Logo
46 people viewed this question
Top Euro-Pro Vacuums Experts
 Tony C
Tony C
Level 1 Expert
Marvin
Marvin
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
