Question about GE Dishwashers
Profile triton 1st water not draining, now no water is pumping
  • 51 Answers
Could be your pump and drain hose but first I would check the drain hose. There is a drain hose for your dishwasher that often gets clogged. Remove the drain hose and clean it out. reinstall the hose and your dishwasher will drain. The dishwasher should have a panel to remove and then comes out easily, just be careful not to pull it out too far. If this does not fixya then you may need to throw some parts at it, but hopefully not. Good luck
Posted on Jul 13, 2009
GE Triton 24
Hi
Please note that dishwashers don’t drain out the complete water such that heating element doesn’t overheat.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please post back for any further assistance.
Daniel
Jul 23, 2010 | GE Dishwashers
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Ge PRofile Mod # wpsr31001ww
CHECK THAT DRAIN PUMP IS NOT CLOGGED, THEN CHECK DRAIN HOSES, . IF NOT CLOGGED, IF GOOD THEN CHECK PWR TO DRAIN PUMP. IF U GETTING PWR TO PUMP,AN NOT SPINING OR HUMMING REPALCE PUMP
Aug 19, 2009 | GE Profile WPSR3100W
GE Profile top load washer purchased 2003 water comes out from under washer when spin and drain cycle on. this not mentioned in trouble shooting area. think it is water pump or whatelse can it be?
It has to be in the water exit path somewhere - is there a pump sump inspection? Is there a hose split? Likely the drain hose, or where it connects to the machine. Has the pump split open? Can you remove the machine cover and inspect it while it is doing a cycle so you can see where the water is coming from?
Apr 26, 2009 | Washing Machines
GE Triton dishwasher will not drain and after cycle.
Look at the timer to see if the contacts have finally worn off. The circuit board may have failed too.
Nov 09, 2017 | GE 24 in. GSD4320Z Built-in Dishwasher
Triton XL GE Profile Dishwasher does not wash dishes well, but in particular, leaves a cloudy film.
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap Aclog in the drain line or air gap (if there is one) is the usual reasonthat a dishwasher won't drain. Often the problem is at the point wherethe drain line attaches to the garbage disposer or household drainline. If you remove this line, you can clear any debris from the hoseor hose connection. Be sure to reattach the hose before starting thedishwasher again.
Pump Yourdishwasher pump ejects the water. The pump is usually mounted directlyto the motor, then attached to the bottom of the dishwasher. You canreach the pump from inside the dishwasher, but first you need to removethe lower rack, the spray arm, and the spray arm support.
Lookfor an impeller--a round plastic fan blade-type of device that spinsaround. This is the wash impeller, which forces the water through thespray arm. Beneath the wash impeller is the drain impeller, which issimilar in size and shape to the wash impeller. The drain impellerpushes the water toward the drain port. These components make up thepump. If any of the pump components are defective, you need to replacethem.
Drain valve and/or solenoid Manydishwashers use a drain valve with an electric solenoid. Whenelectricity flows to the solenoid, the valve opens and diverts thewater to the drain. Sometimes the solenoid, or the diverting lever,sticks and prevents the dishwasher from draining or filling properly.Try to free up the solenoid to lubricate the lever. Otherwise, you mayhave to replace the solenoid or pump assembly. With these systems, themotor always rotates in one direction. When it's energized, the drainvalve diverts the water.
Other dishwashers simply reverse thedirection of the motor to drain the dishwasher. These units don't havea drain valve. Instead, there's a drain hose connected directly to thepump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor Ifthe motor isn't turning or working, the unit won't drain. First checkto be sure you have power to the dishwasher. If not, see the section"It doesn't work at all." If the motor hums but doesn't turn, it mayneed to be replaced.
Some dishwashers are susceptible togetting stuck if you don't run them regularly. If you haven't run thedishwasher for more than a week, you may need to manually spin themotor to free it up. If the motor is defective, you need to replace it.Dishwasher motors can't be serviced.
Timer Partof what the timer does is control the motor and drain valve. If thetimer doesn't work properly, the water may not drain and you need toreplace the timer. This problem is uncommon.
As for testing water hardness, you can find these at your local plumbing store, or even the electricals where you bought the dishwasher from.
Hope that helps!
Sep 28, 2008 | Dishwashers
GE TRITON LX Dishwasher
First check your Drain Cup filter it is just under the lower spray arm you may have something blocking the drain... if its clear check the drain pump... does it run a drain out? can you here it make noise? let me know if this helps ?
Aug 14, 2007 | GE ZBD5900D Dishwasher
Dishwashers Logo
82 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
