Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Seagate FreeAgent 1TB - I/O device error
My 1TB FreeAgent was working just fine and then it just stopped. My Vista machine can see it as a drive connected to the computer, but it can't access it and gives me an error message saying that there is an I/O device error. I hooked it up to my XP machine and it locked up the device detector. I suspect the problem has to do with the external device talking to the computer, not the files stored on the drive itself. I contacted Seagate and asked what to do - I've had this drive for less than a year. They failed to respond to my questions regarding warranty coverage and told me I needed to pay for a data recovery service. What to do?
  • 3 more comments
  • azachry Jul 13, 2009
    Ekse,
    I got an error message that reads: "Access Denied as you do not have sufficient privileges. You have to invoke this utility running in elevated mode."
    Anne
    I right-clicked on the drive and "Computers" was suddenly "(Not Responding)" and I got the Vista "ring of death" for a few seconds, then nothing happened. I did this several times with the same response. The box did not pop up to give me the option of selecting "Properties."
    What I got, after waiting for it to think about it for a bit, is a message that reads: "The type of the file system is RAW. CHKDSK is not available for RAW drives."
    I think I want to try and get my data off the drive before I try to format it. But, I'll try your strategy once that's done. I agree that it's probably time to send it in. The unit is still well within warranty and they will send me a new one, but they want to charge me to get my data off of it. Looking at all the other postings of other people who have had similar problems, I'm concerned that it's just going to happen again, though. I guess I'll just have to see. Thank you very, very much for taking the time to help me with this. You've gotten me a lot farther than I ever would have gotten on my own with this problem.
    Ekse took me through a lot of constructive steps to try and figure out what was going on. I couldn't have gotten this far without his help.
  • 13,433 Answers
Hey
you can check your warranty info here
http://support.seagate.com/customer/warranty_validation.jsp
Warranty - repair / replacement should be free. They will charge for data recovery.
You could hook it up to another case or directly into your computer to see if it works. But It would void the warranty as you would need to take the case apart.
What you can try though, is connect it to your computer and find out what drive letter it has.
Then open up the run menu by pressing windows key and then R, in run menu type in CMD and press ok
Type CHKDSK /F /X H:
Replace H: with the correct drive letter.
Let me know the results of the scan or do you receive a error?
Posted on Jul 11, 2009
  • 2 more comments
  • Ekse Jul 13, 2009
    Alright, lets try this instead, open my computer from your desktop or from start menu - > computer
    Right click on the drive, select properties. Then open the tools page, then click on ERROR CHECKING - CHECK NOW
    Optiuons:
    Automatically fix file system errors, make sure its checked.
    Also Scan for and attempt recovery of bad sectors.
    if you get a message, windows can't check the dist while its in use, click schedule disc check and restart the computer.
  • Ekse Jul 13, 2009
    Okay, in that case follow these instructions:
    Open notepad. (hold down windows key and press r - then type notepad and click OK)
    In notepad type the following
    @echo off
    cmd.exe
    Thats all, remember to press enter after @echo off.
    Now click File - Save As.
    Save the file to your desktop, name the file exactly: run.cmd
    Change the file type to ALL
    Click save.
    On your desktop you should have Run icon with a special gear in the center.
    Right click on the icon and select Run As Administrator.
    Now your in the same cmd promt as in the first suggestion, now type
    CHKDSK /F /X H:
  • Ekse Jul 13, 2009
    Its starting to seem like a mechanical problem with the drive, are you in or outside of warranty?
    Try this
    format H: /FS:NTFS /X
    Replace H with the drive letter, we are trying to format the drive, if the format fails, Time to send the drive to repair. Check your warranty here http://support.seagate.com/customer/warr...
    If you are outside of warranty and you wish to try a few more things with it, you could remove the hard drive from the case and connect it directly to your computer to see if it works, if it does, then the issue is either the power adapter if it uses one or the usb case is faulty. you can purchase a new usb case if you like.
  • Ekse Jul 13, 2009
    I personally use filescavenger for file recovery, also, format does not write over the content so the contents are still intact on the disc and recoverable with a file recovery software. Unless the head of the drive has crashed and in that case the head would be dragging along the whole disc making it completely un useable.
    File Scanvenger is a great file recovery software, I've recovered pictures from computer hard drives and memory sticks that where format and even somewhat written over, some of the content has always been recoverable.
My Seagate 1TB FreeAgent external Harddrive is not working on my laptop which is running on XP. In Manage Hardware section this device is shoing as unknown hardware.
go here
And download for windows. You see most companies like you to download the software from their website for older operating systems for your computer to recognize it.
Thanks, Cody
Sep 11, 2012 | Seagate Freeagent Go 1 TB Hard Drive
My seagate 1TB external hard disk (the little compact one) cant be read anymore. Was working fine a couple of days ago. The lights on top are flashing constantly. After the drive is plugged into the...
Right click "My Computer" >properties> hardware> device manager. Expand "disk drives". Right click your seagate drive and click uninstall. Reboot your computer; the drive should automatically be reinstalled.
Feb 10, 2011 | Seagate FreeAgent Pro 1TB External USB...
While copying the files from C drive it started giving Error: 080070057
Can you copy those files to a USB memory-stick?
Do you get any error-messages when reading from your 'C:' drive?
If yes, then your 'C:' disk-drive is "dying".
If no, then your disk-drive is OK, and its the external storage device that is "dying". Make a backup of the files on that device, if you can.
The only "good-news" is that the Seagate probably still is under warranty -- Seagate will replace it, at their cost, not your cost.
Oct 23, 2010 | Seagate FreeAgent Pro 1TB External USB...
Seagate Freeagent not recognized, not in device manager either
OK 1. Go to Start>> Right click My Computer>> Manage>> Device Manager 2. Expand the USB Controller section 3. Right click and Uninstall all of the listed USB devices 4. Reboot the system
Do this with NOTHING plugged in at all. Plug back in AFTER reboot. Then it may/should all work again.
Mar 05, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Freeagent Go not recognized as an identifable USB device.
I plugged mine's directly through the back of my computer instead of the hub in the front and it's working fine.
Mar 02, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Windows cannot read my external hard drive anymore. It is tells me to unitialise it, and windows cannot even help because of an I/O device error.
Please check the External Hard-drive to some other computer
it it is working fine then check the services and turn on the plug and play
start - run - type services.msc
select the look for Plug and Play
Jan 03, 2010 | Seagate FreeAgent Pro 1TB External USB...
Seagate 1 TB not detectable on win 2003, xp detects it
As you know,the Seagate sometimes has the firmware problems,so it seems that this firmware designed only valid in XP or Vista system,you may find the firmware update from the seagate official website
Jun 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
USB port broken in 1TB seagate Freeagent external hard drive
This listing (260320213027) has been removed, or this item is not available.
IS THERE ANOTHER SITE THAT WILL FIT MY SEAGATE EXTERNAL HARD DRIVE, 1TB?
Feb 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Does Seagate Free Agent 1TB support Windows 2003 Server
Go to Computer Management. (compmgmt.msc) then to Disk Management and assign drive letters .
u will c ur disk.
Jun 19, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
488 people viewed this question
Top Seagate Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
