Question about Dometic RM2652 Refrigerator
No power to eyebrow board on dometic 2652
We have a dometic 2652 there is power coming in to the board but no power on the eyebrow board. Any suggestions?
  • 20 Answers
SOURCE: Rm 2652 stays on a while then cuts off and stays off
If you have the yellow epoxy filled circuit board from around 1993-1996 rather than the green newer one you can see the circuits on (take the black cover at back of fridge off to check) it is most likely just a bad circuit board. Otherwise it is most likely low voltage or a bad ground on the 12volt power coming into the fridge. Also make sure your thermostat(if available) is on maximum during testing.
Posted on Feb 20, 2009
SOURCE: My dometic 2652 runs is not cooling on gas or
Is there a yellow powder substance on the coils, heating tube or anywhere towards the bottom? If so, you have a leak. The best thing to do is:
1-Find a replacement unit online( ebay is a good place to start)
2-unhook electric line and gas line from the access panel
3-remove the refrigerator from the inside and place doors down(its heavy and you will probably need another person to help)
4-remove cooling unit from back of refridgerator
5-make sure you have enough thermo-mastik for the unit/coil contacts
6-replace cooling unit and hook up everything in reverse
7-turn on and let it cool for a few hours. My unit stays below 32F and works great.
Found the first one listed on ebay just now for $399.00 with a five (5) year warranty.
Posted on May 27, 2009
SOURCE: light is not working in Dometic rv fridge.
the light switch was burned out. we orded a new one, thanks for the reply. judy
Posted on Jun 06, 2009
pride applia
  • 232 Answers
SOURCE: Dometic RM 2652 has no power and blows fuse in the
brand and model # please
Posted on Jul 02, 2009
  • 127 Answers
SOURCE: Info on replacing drain hose on dometic model 2652
You will need to remove the fridge and set it on the floor or at least pull it forward enough to reach the top of the drain hose. There is clip that holds the drain tube to a nipple that sticks out of the back of the fridge that will need to be removed. Remove this clip and the drain hose should pull right off. Route the new drain hose down through the cooling unit coils to the door panel. Attach it back to the nipple with the clip and you should be good to go. The part number for the new drain hose is 2932749019.
Hope this helps,
Jeff
Rate me please!!
Posted on Jul 03, 2009
I have a Dometic 2652 , the electricity to it is good, but the refrigerator lights on top will not come on and nothing works!
Either there is no 12V going to the refrigerator or a fuse is gone in the electronic board on the rear of the refrigerator.
ArctiCold Refrigeration We keep it cold 25204865-k2m0naq5ofddvqgkm1ezk3hy-4-1.png
Oct 10, 2014 | Dometic RM2652 Refrigerator
No power to inside on/off switch 120v or 12v, i checked with multi meeter
You either have a bad harness from the main board to the eyebrow board or the eyebrow board is bad. You can open the freezer door and snap the upper cover off of the refrigerator which will expose the harness. The harness will be secured to the back of the eyebrow board with a small plastic band and a screw. you can either disconnect the harness and tie/tape a string to the harness which will allow you to reinstall the harness after testing or you can make a long jumper that will connect to the harness and allow you to test the continuity without removing the harness. Either way you need to check the harness for continuity and also verify that there aren't any shorted wires. If the harness checks good, then it is probably a bad upper circuit board (eyebrow board).
Apr 09, 2014 | Dometic Refrigerators
Eyebrow temp control not working
disconnect thermistor on backboard run overnite if ok replace thermistor if not bad control board
Jan 27, 2014 | Dometic Refrigerators
Dometic RM 2652 Refrigerator/Freezer is not working. Light works, 110 and propane are fine. Are there steps in trouble-shooting problems with this refrigerator? No visible leak or obvious problem. It's in...
Dometic refrigerator lp gas electronic Model # 3662. Same problem. gas works fine and power is there. as lights on top of frig work.... not even trying to be cold. Same suggestions as 2652? How to bypass thermostat? and will try relay after... thanks.. Bob in Canada<input id="gwProxy" type="hidden" /><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden" /><!-- from fixya rte -->
Aug 02, 2010 | Dometic RM2652 Refrigerator
I changed cooling units and now i dont have any power going to the refrigerator dometic 2652
I would check the lower circuit board it has a few fuses,main fuse. And you should download and print the Diagnostic service manual.
Roy
Jul 29, 2010 | Dometic RM2652 Refrigerator
The power and auto lights will not come on, but there is power (110V)and no blown fuses on he 12 volt.
If you have power to the refrigerator, then access the rear panel and remove the cover from the control board on the left lower side. There is also a 12V located on this board. Check to make sure that 12V is passing through the fuse to the board. If all seems ok, you need to check the eyebrow board. Remove the front cover of the fridge and check for 12V at the eyebrow. If it is there, then replace the eyebrow board.
Jul 08, 2009 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
193 people viewed this question
Top Dometic Refrigerators Experts
Sheldon Dedek
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
