Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500
Replaced Poulan 25cc weedeater fuel lines/Now no start
My Poulan 25cc weedeater fuel lines cracked so I replaced the. The weedeater started on 1st pull, but died when i tried to accelerate. I am not certain how long the fuel lines need to be inside the tank, or if length is important. I have them about half way to bottom. Also there seems to be a small connector for the larger line that came out of the tank. I dont know where this part goes. Is it important?
Thanks in advance,
Brian
  • 279 Answers
You have/had a fuel filter in the tank.The connector goes to that filter, I think. The length does mean something but I don't know any way to figure it without a manual. You could try to figure from the total length. The fuel filter hold the line toward the bottom. Good luck.
Posted on Jul 14, 2009
Weedeater carb. which fuelline is pickup? which is return
The return line will go from the back side of the carb to the fuel tank.
Sep 12, 2016 | Poulan WeedEater Hedge Trimmer 25cc Engine
Starting problem.
Yes, that was the fuel filter. If it was loose then your fuel lines are probably bad. They will need to be replaced.
May 12, 2014 | Poulan Pro 25CC 2Cycle Gas Blower
POULAN 25CC NOT STARTING AND BEFORE THIS HAPPEND IT WAS OVER HEATING
overheating on a 2 stroke is usually caused by lack of oil mixture. try draining all the fuel and re mixing the ratioo to a 40 to 1 ratio. if no smoke then richen the mixture till it slightly smokes. i.e. 50:1 ratio
Aug 30, 2012 | Poulan WeedEater Hedge Trimmer 25cc Engine
Will not start. Worked OK when last used a month ago. Does not appear to be getting fuel. Started only once with engine start fluid. Removed fuel line(s), filter was off. Has one large line for filter and...
the line with the filter is your fuel intake put the filter back on but in most cases check the lines to see if they are real soft if they are replace them also check for cracks and holes if filter is dingy or dirty put a new one on
Feb 19, 2011 | Poulan 25CC Gas BlowerVac
I just put new fuel line on my trimmer now i cant start it not getting fuel the line never fills with fuel but i can **** fuel out so i know it not pinched it a weedeater brand ght-17
Make sure the little valve under the tank if you have one is fully turned clockwise. Make sure there is nothing clogging the tiny screen inside the fuel tank. Check or test your primer bulb it may be leaky. If carb or intake is leaking, you won't get gas either. If you have a filter on this model, try changing it.
Sep 10, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
31cc Poulan Pro Weedeater
Sounds as though the fuel filter may be plugged. The filter is in the tank. Take a look, see if it is visible. Remove and replace. Good luck...Lee
Jul 26, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
I have a Poulan WeedEater. It had trouble
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 24, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
My weedeater want start change spark plug
I would have a cylinder compression done on the engine before spending any more money. It may be below 100 psi and will not run. Plus if your fuel mixture is over 30 days old I would mix up some fresh fuel mixture.
Or the diaphragm in the carburetor has become stiff and is not pumping any fuel.
Good Day.
Oct 12, 2009 | Poulan WeedEater Hedge Trimmer 25cc Engine
Poulan Weedeater GHT-22 Hedge Trimmer Leaks Fuel Near Handle
Either the fuel lines that were replaced are a poor fit in the tank ( wrong diameter pipe ) or the pipes have been connected incorrectly to the fuel primer bulb.
Dec 13, 2017 | Poulan Garden
Ght225 Weedeater hedge trimmer
try sanding the fly wheel and the coil to get the rust off
Jun 17, 2009 | Poulan Ght225 25cc Gas Hedge Trimmer
Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500 Logo
1,336 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
roeb
Jay Finke
Jay Finke
Are you a Poulan Garden Expert? Answer questions, earn points and help others
