Question about Dyson DC14 All floors Bagless Upright Cyclonic Vacuum
Vacuum is not turning on. Is there some kind of a reset switch or a fuse that could have gone out?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 83 Answers
There is no reset switch. First try a different electrical outlet. If that doesn't work, you may have to replace the power switch. Call the Dyson Helpline, they'll register your vacuum cleaner and direct you to your nearest repair dealer.
If your machine turned off whilst you were using it you have a blockage in the machine and you are experiencing a Thermal cut-off. Call the Dyson Helpline, they will talk you through looking for a blockage and help you find it.
Posted on Jul 29, 2009
Why wont my vacuum start when I turn it on
If you are in the UK replace the fuse in the plug
Oct 19, 2014 | Vacuums
Panasonic vacuum cleaner just stopped running
Set the on/off switch to off, now check near the top of the "beater" portion, I think that model has a reset button, you should hear a slight "click" when depressed. Try turning the vacuum back on.
Aug 26, 2014 | Panasonic MC-V5217 Vacuum
Vacuum stopped while sweeping the floor
it is either the switch or the motor buy a brand new switch to put on it and if that does not solve the problem then the motor is just trash but the switches go out on these kinds of vacuum cleaners all of the time so that is probably the problem but if not the vacuum is trash
Mar 23, 2014 | Hoover Vacuums
My dyson dc07 wont turn on. is there a motor reset button on the dyson dc07
no it does not have a reset button av you checked the fuse in wall plug if OK it's most likely the switch as gone bad here is a video how to replace
Apr 02, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Cannot get it to turn on
This could be because of 4 reasons.
1. Fuse in plug has gone - Check this first
2. Switch has gone - Unlikely
3. Powercable is disconnected from the switch
4. Motor has failed
Try number 1 first and then come back to me
Jan 14, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a Hoover Mach 2.7 Windtunnel that shut off during use and wouldn't turn back on. Was doing kitchen floor and running fine. Though a breaker tripped but didn't...what could it be?
It sounds like your thermal reset switch inside of your Hoover may have gone bad. When a vacuum cleaner doesn't turn on it, it's either caused by one of four things.
  1. Electrical Short in your Cord.
  2. Plug has gone bad.
  3. Motor of your vacuum is faulty
  4. The On / Off Switch has gone bad, and/or your Thermal Reset Switch has gone bad
Since this happened while you were vacuuming, I would guess that this is either your electrical plug that's shorted out, or that your thermal reset switch has shorted out. Your model Hoover was built with a protection system that is supposed to automatically shut down your machine if it senses any excessive heat. This mechanism is controlled by a Thermal reset switch which is located in motor compartment. This part is notoroious for failing, even when there's no overheating that's occured.
Before you disassemble the entire machine to check this part though, I would try testing the On / Off switch in your machine, as well as testing the electrical cord, which will also let you know if your plug has gone bad.
Here's a link to a solution I've done here on FixYa explaining how to check the On / Off switch;
http://www.fixya.com/support/r4530569-replace_off_switch_hoover_windtunnel
While you have this apart, you can use the same electrical tester to test your cord. Simply put one end of the test into the terminal from the switch, and the other end of the test on one of the metal prongs that plugs into the wall. See if you have continuity here, if not, switch to the other prong of the plug and see if this helps.
If not continuity, this means your plug, or your cord has failed. If you do have continuity, this means that it's either the On / off switch, or the Thermal Reset Switch that's gone bad.
Here's a link to the solution that I've done on here showing how to replace the Thermal Reset Switch on your vacuum cleaner:
http://www.fixya.com/support/r4999778-replace_thermal_overload_switch_hoover
If you'd like some more help diagnosing this vacuum, please feel free to just use the comment field on the bottom of this page. I'm always happy to help you do some more advanced diagnosing, or answer any questions you may have.
If you found this solution helpful, please be so kind and rate this repair helpful, or leave feedback for me. This is greatly appreciated by the FixYa community. Thanks so much,
Chris Jones
GoVacuum.com
Jan 10, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuum will not turn on
Kenmore Model 116, behind the Vacuum cleaner there is a Motor Reset switch which you need to press.
1. Make sure the Vacuum Cleaner is unplugged.
2. Press the reset button gently in with a pen.
3. Plug back the Vacuum cleaner and it should work.
Jan 31, 2009 | Vacuums
I was vacuuming then all of a sudden the vac turned off and wont go back on. i thought the bag might be full so i emptied it and still it wont go back on
Greetings from GoVacuum.com,
There maybe several things wrong with the vacuum at this point. When a vacuum cleaner doesn't turn on, it usually is 1 of several things. It's either a reset button on the machine, the cord, the plug, the switch or the motor. One of these things have gone bad in your machine.
If you'd be so kind as to let me know your make and model, I can help you diagnosis the vacuum to find out what went bad.
Please email me your make and model to chris.jones@govacuum.com
Chris Jones
GoVacuum.com
Oct 15, 2008 | Vacuums
Suddenly the vacuum won't turn on
Could be a number of reasons, may have a bad cord, If the switch is on the hose, it may have gone bad. Could even be a motor problem. Needs to checked to find the problem.
Mar 13, 2008 | Kenmore 23812 Progressive PowerMate Bagged...
Dyson DC14 All floors Bagless Upright Cyclonic Vacuum Logo
339 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
