Question about RCA 14F512T 14" TV
Sound Issue Cable ComCast, I get sound on some channels and no sounds on other channels. On channel 12 I get the sound from channel 13. Can this be fixed or what is going on?
  • 1,694 Answers
Re: Sound Issue
SAP = Second Audio Program is on = de-activate.....T.
Posted on Dec 08, 2007
  • 298 Answers
Re: Sound Issue
Try with another set or two may be Comcast problem or a bad
cable If problem is isolated to TV then the mode sw may be
suspect antenna, cable ....
Posted on Nov 15, 2007
0 characters
3 Points
No Volume from cable input
The sound is probably set to the SAP channel (language) and the SAP channel is not active on the program you are watching. Just push the SAP button on the remote. The button might be labelled SAP or LANG. This will return you to the main sound channel which is always active.
Apr 18, 2014 | RCA F32645 32" TV
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
I have a Panasonic TAU CT-27SC14J TV lost sound
Ur video/Audio board have a short or lose a connections.Must take it aparts retighten everythings,might even resoldiers the parts.
Aug 19, 2009 | Standard (CRT) Televisions
you should have a button on your remote for sound system may be 'BG' or 'SYS' or any other press it to change sound system to "BG". sound will be ok.
Nov 01, 2008 | JVC AV32F476 32" TV
Cable tv issue
first ,replace the tv-dvd cable,then ask me again.
May 04, 2008 | Toshiba 36A40 36" TV
No sound on just one channel
Do you have another TV in house that works with this channel correctly? Do you have a VCR (or VCR/DVD combo) that you can use to tune to this channel? I'm wondering if your tuner is going bad on this one channel. Do you have SAP (Second Audio Program) turned on? You may want to turn it on and then check channel for sound. I'm assuming that you're getting your cable feed thru coax and not composite (red & white audio). If you are using composite, try switching the red & white inputs to see if sound comes in. It's possible that cable company is only outputting audio on left or right channel and something is wrong either with one of your TV's speakers or with the cable company's output.
Mar 06, 2008 | Orion STV2763 27" TV
No sound on my 8year old panasonic tv.
It worked fine yesterday. Sound on all channels. Sometimes the picture goes black on channel 6. We can get it back by going up one channel, then back to 6. it is due to cable signal ie weak. now there is no sound this is due to sound section 1 loose connect in sound section 2 speaker 3 problem in sound section some part must have failed.
Sep 17, 2007 | Panasonic CT-32SX12 32" TV
A lot of white noise appearing on Panasonic CT-27SL13 27 using COMCAST
You maist likely have bad ground connections inside the tuner of this TV set. Good Luck
Jun 23, 2007 | Panasonic CT-27SL13 27" TV
Black Square Covers 80% of screen on most channels on TV
have your tv checked by a tech.probably your chip the eprom needs to be reset by lifting it up from the board and resolder back.some one could have put in a code for those channel.good luck.
Dec 27, 2006 | Toshiba CF35E50 35" TV
RCA 14F512T 14" TV Logo
115 people viewed this question
Top RCA Standard (CRT) Televisions Experts
John mullen
Are you a RCA Standard (CRT) Television Expert? Answer questions, earn points and help others
