Question about Garden
How do you clean carburetor in statesman tiller? Tiller has been sitting for about a year and there is rust in gas tank as well.
Take the carb off and take it apart then clean it with some thing flamable so it burn off with the gas.
Posted on Jul 11, 2009
My rear tine tiller, 18 inch - model #21AA40M1029 by yard machine has been sitting in my storage shed for two years and will not crank. I have changed the old spark plug with a new one and I have drained...
need to check for spark---- magneto [magnet-pulse to coil] may have rust causing failed spark can clean lightly with sandpaper but more than likely u need to clean the carb-buy a rebuild kit about 10 bucks -take off carb tear apart and let soak in parts cleaner use a carb cleaner and spray all the nooks and crannys in carb rebuild replace and try firing up because more than likely the carb is completely gummed up from the old gas
Jun 08, 2011 | Yard Machines Tiller 208cc 18in Tilling...
I have a 2-cycle Matis Tiller that was sitting for a while and will not start. I replaced the old gas with new, replaced spark plug, adjusted high/low set screws and choke to no avail. Can the carburetor...
Hi, I also have a small garden tiller (not a Mantis) that experienced a similar problem. What I did was remove the carberator and completely cleaned it with standard spray carb. cleaner (this is available at ant auto parts store or Wal-Mart). After I cleaned and reinstalled the carb. it ran fine. This was two years ago and it has been running fine since. What I believe happened was the gas evaporated and the remaining residue from the gas "gunked" up the carb. Once it was removed, the problem was solved. If this does not work, take a look for any broken wires. Sometimes a rodent will make a meak out of a wire. This happened to one of my cars. Good Luck!
Jan 09, 2011 | Mantis 2-Cycle Tiller
Tiller starts and runs for a few seconds only with choke on
Sounds like you have a dirty carburetor. Might be able to get it going with a dose of carburetor cleaning in the gas tank (Sea Foam is good), about a 1/4 cup is more than enough. You need to start and run it a couple times to work the cleaner in to the carb. Then, let it sit a day or so.
Other than this, remove carb and do a good cleaning with spray carb cleaner in all the jets. If there is a brass bolt on the bottom of the carb that holds the bowl on, it may very well have 1 or 3 itsy bitsy teeny tiny hole, almost invisible to the naked eye. They HAVE to be open. Did I mention that they are small???
Aug 09, 2010 | Cub Cadet 1 Rotary Tiller Operator ...
The tiller has sat idle for several years
Remove carburetor clean very good, replace needle valve and carb gaskets. Drain fuel tank and wash it good making sure there is no trash or rust. Change the oil and making sure to not over fill.
This is the procedure I have used many times. Hope this will help
Apr 16, 2010 | Troy-Bilt Pony Garden Tiller
My tiller only starts when I pore gas into the carberator air inlet. Then it surges for a couple of seconds and cuts off
IF THE TILLER HAS BEEN SITTING A WHILE I WOULD CLEAN THE CARBERATOR SOUNDS LIKE GUM BUILD UP. I HAVE HAD LUCK WITH DRAINING ALL THE OLD GAS AND DUMPING CARB CLEANER IN THE TANK WITH GAS AND KEEP TRYING TO START SOME TIMES THE CLEANER WILL DO ITS NJOB AND CLEAN THE GUM OUT OF THE PORTS IN THE CARB
Oct 12, 2009 | Troy-Bilt Pony Garden Tiller
Statesman Tiller
without knowing if its a briggs and straton or tecumseh engine ( I assume Briggs) the carb is where the throttle and gas line connect to. carb will need to be rebuilt most likely and tank will have to be removed to be cleaned. you can email me and I could do it for you I am in wisconsin kerryjonjon at yahoo.com I am the most reasonable in this area. I could do carb and tank if you want.
Jul 11, 2009 | Garden
I have a Bolens 6.0 OHV tiller M# 21A-332C163 and S# 1C283K40098. It will start on first pull but only run 2 or 3 mintues then quites. You then have to choke it to restart it then again it will only run...
Has it sat with gas in it ? if so carburetor needs cleaned,The other thing could be water in gas look in tank for something that looks like a bubble floating in bottom of tank if you see one its water you remove tank clean out then if carburetor has bowl you must remove carburetor bowl clean out water.
May 04, 2009 | Garden
Mantis tiller runs but bogs at full power then stalls
The problem is in your carburetor. Glaze can build up over the winter and cause this very problem. You can try a fuel additive which will clean the carburetor available at any auto parts store since it does run. However, if the problem continues the carburetor may have to be soaked in a cleaner for two hours and rebuilt
May 04, 2009 | Mantis 2-Cycle Tiller
I cant get my tiller to rev up.
most problems are due do a fouled carb, because of old fuel most of the time, take the carb off and separate it from the tank and give it a good cleaning and replace with new gaskets and carb parts, use carb clean and air pressure to clean,
Apr 21, 2009 | Garden
5 hp Briggs and stratton wont run on a MTD tiller.
I had the same problem a few years back. Check the rubber elbow coming from the gas tank to the carb, it's probably cracked and sucking air instead of fuel from the tank.
Nov 30, 2008 | Garden
Garden Logo
194 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
