Question about Amana Dryers
Amana LG4409L Gas Dryer: Ignotor comes on when
Amana LG4409L Gas Dryer: Ignitor comes on when dial switched to Heat, but apparently no gas comes out of the regulator because the ignitor eventually cycles off. Switching the dial between Delicate, No Heat and Heat does nothing other than briefly turn on the ignitor. Should I assume the problem is the regulator, and order one?
    Top Expert:
  • Amana Master
  • 49,110 Answers
The igniter or gas valve could be defective.
Posted on Nov 18, 2017
aborcass
  • 2651 Answers
SOURCE: Amana ALG443RAW Gas Dryer will not heat up.
you can remove the lower acess panel (2) 5/16 screws along bottom. youll get a good view of workings there. turn on dryer (make sure a heat cycle is selected. you should see the ignitor light with in a few secs. if not unplug the ignitor(small white connector maybe 6inhes back from ignitor itself) and with a meter ck for 110v in that connection when unit is turned on, if you do have 110volts , you hav abad ignitor. ifyou dont get 110 volts you need to check the thermostat(s) located on top of the heater box right above the ignitor, if no continuity you need a new thermo.
Posted on Mar 12, 2008
  • 14 Answers
SOURCE: no heat-gas dryer--Amana
There is a flame sensor on the side of the flame housing. Jump the 2 wires out and see if the ignitor glows then. If so you need a flame sensor.
Posted on Jul 25, 2008
docjohn174
  • 943 Answers
SOURCE: Kenmore Dryer - Ignitor will not fire
thanks for the question The problem is with a thermal fuse located at the back remove back panel the thermal fuse is located on the air vent 2 small wires go to it replace it . And check the venting make sure the vent is clean because this termal fuse will break down because of poor venting Thanks for the question The appliance doc
Posted on Sep 11, 2008
  • 71 Answers
SOURCE: Amana Dryer ALG643RBW ignitor glows, gas fires for a couple secon
valve coils
Posted on Dec 24, 2008
jsrock516
  • 5911 Answers
SOURCE: ignitor will lid for a few seconds
This is commonly caused by a weak igniter. Over time, the igniter wears out and does not draw enough current to open the gas safety valve on the burner assembly. This is a designed safety feature that prevents free-flowing gas from entering the dryer cabinet without ignition. The following link explains how these igniters work:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
I know the link is for a gas range, but the types of igniters and theory of operation is still the same. In effect, your igniter may have the appearance of working correctly by glowing, but it may be too weak for ignition to occur. I would recommend you try replacing the igniter.
If you have quesitons, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Posted on Jan 28, 2009
AMANA GAS DRYER, MOD.#LEA1OW/LGA10AW . CLOTHS WILL NOT DRY-IGNITER LIGHTS, BUT GO OUT BEFORE BURNER COMES ON.NO HEAT.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | Amana Dryers
Ignitor glows gas valve opens, burns for a while then gas valve closes and ignitor cycles , if dryer is off a while it will light again. amana
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 24, 2010 | Amana Dryers
The ignitor glows, the gas comes in, it lights then goes out!
heatman101
Sep 14, 2010 | Amana DLG330RAW Gas Dryer
I have an Amana LG4319w/l2 gas dryer converted to Lp gas. The ignitor comes on but will not ignite the gas. Theis happened before and the technician replaced the ignitor and said the ignitor must dray a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Sep 11, 2010 | Amana Dryers
Dryer will not heat. where is ignotor located...
heatman101
May 19, 2010 | Maytag MDG7600AW Gas Dryer
I have a frigidaire electric dryer the drum spins but no heat cant find fuses that i have been told to cheack. help
there are no fuses on this unit, you will need to verify that the ignitor is not glowing. if it is glowing and the gas is not being let in. you have bad coils on top of your gas valve. if the ignotor does not glow you have a faulty ignotor.
Oct 20, 2009 | Frigidaire Dryers
Amana dryer wont work
I'LL let you know after the Amana repair man comes out.
Mine is doing the same thing and I can't figure it out
Jan 14, 2009 | Amana NDG2335AW Gas Dryer
Amana ALG331Raw Problem
replace the valve solonoids, classic week solinoid problem.
Sep 10, 2008 | Amana ALG331RAW Gas Dryer
No heat-gas dryer--Amana
Jul 25, 2008 | Amana ALG331RAW Gas Dryer
Dryers Logo
96 people viewed this question
Top Amana Dryers Experts
Sal De
Marvin
Marvin
Craig Butler
Craig Butler
Are you an Amana Dryer Expert? Answer questions, earn points and help others
