Question about EliteGroup P4VMM2 Motherboard
Problem with my Motherboard
My computer is having a problem, it keeps on hanging even I change the processor and also change the memory. Now it gets worst, the computer is not turning on. I replaced a power supply, but still not working. I expected that my motherboard is the problem. Is there anything that I can do with it?
  • 2 more comments
  • Royal06 Nov 18, 2007
    thank you for your helf, but i already tried reseting my cmos.
  • roel082980 Nov 22, 2007
    i have problem in my board p4vmm2. i already change my power supply but still no power. i think its a problem of my motherboard. can you help me please?
  • zenpal Jan 03, 2008
    I turn on the power supply switch and turn the front panel power switch and the fan comes on for a second and stops. No lights. No beeps. Is the motherboard bad or the power supply bad or is it something else
  • hatcho Jan 24, 2008
    my computer is hanging and the monitor turn its color into green what does this cause? thanks..
Was working on this model mobo tonight with a friend. Ran into the same exact problem, and tried leaving only mobo and the HD connected. Also tried nothing but the PSU and the mobo.
Will come on for appx 2 seconds and then shuts off. Tried 4 different known good PSUs. I am assuming that there is a problem with the Power good pin thats causing the PSU to cut power off to the motherboard.
Posted on Nov 30, 2007
We did that
went as far as to disconnect everything cept power to the mobo
I tried all
just the hd
and nothing but PS and mobo
  • 143 Answers
Have you tried to reset the cmos
Posted on Nov 15, 2007
  • marco amezcua
    marco amezcua Nov 18, 2007
    what i would try next would be to disconnect all cd roms anything you have connected to the computer only leave the hard drive connected see what happens k get back to me
  • marco amezcua
    marco amezcua Dec 27, 2007
    did you put the cmos jumper back the way it was try to put the other processor back in and do How do I test if the power supply is bad?
    Warning This test is for those with extensive electronics training. Do not try this if you do not have extensive electronics training. Make sure there is enough load connected to the power supply before testing ( at least motherboard and one hard drive)!
    ATX power connector layout isshown above. 5VSB constantly provides 5V power to the connector through pin 9. If you have a voltmeter, while the power supply fan does not turn on, you could identify which pin is pin 9. Normally there is a clip on the connector between pin 15 and 16. If one can identify pin 14 (the only green wire goes to pin 14), this is the power-on pin. Onee can use a piece of wire to short pin 14 and 15 (or any other black wired ground pin). If you power supply has power connected to it and power switch on the power supply is on, the fan should be turning by now. Otherwise, your power supply may have problem.
    this test
My processor is loose thats why pc hangs often! what to do?
Your PC get hang offen mean your memory is not sufficient to your processor to process to try to upgrade your memory , or else you have have virus in your system so that it high your cpu process so that too your PC get hanged. check your cpu speed by clicking ALT + CTRl + DELETE at same time, and check which program utilizing CPU more
Jan 02, 2011 | Intel D845GVSR Motherboard
I have a dell inspiron 531s. it is freezing off and on. it would work well for a day then it would just freeze, not responding to the mouse or keyboard. i have reformated the hard drive change the memory...
I had the same issue. I upgraded to Windows 7 and things did work allot better but the hanging still occured. I ran system mechanic and found there was a drive problem. This was repared by the program.
The problem occured again last night and the system will not boot past the dell splash screen. I am thinking it might be the motherboard that is a fault. Mine is out of its 12 month warranty, so no way to get Dell to investigate further. Also check the systems logs after the hang happens and see if there was something logged that caused the hang.
I hope this helps?
Jan 01, 2011 | Dell Inspiron 531s Desktop Computer
Computer won't run windows XP, only shows F1 & F10 options at the end of monitor. Can't even select any of the options mentioned above. change keboard and still not able to select options.
do the lights on the kbd flash at all?
are there any beeps coming from the computer??
disconnect all your USB devices - even kbd if it is usb.
anything different.
Something is hanging the system during POST because it is not answering the processor. Could also be memory, a hard drive,....
Just try unplugging things till u get a different reaction.
If nothing changes it could be a motherboard issue.
May 17, 2010 | HP Compaq Presario SR1610NX (ED865AA) PC...
I have elite mother board P4 M800 PRO M2 socket 775...the problem is always hang and to slow..i reformat 3 times but the problem same plz help me i need assistance..
This are things that need to consider in a computer speed performance:
1. Amount of ram memory(If you have only small amount of memory then your computer performance is poor.)
2. Speed of your processor(You should need at least a 1Ghz processor speed or more).
I suggest you increase your ram memory so that your computer will perform faster.
Dec 16, 2009 | EliteGroup P4M800PRO-M Motherboard
Computer hang-up when idle and while on handycafe mode
First, the supplier didn't need to replace the expensive motherboard. They likely did this because the graphics card was built into the motherboard. Rather than installing a video card into its own PCI slot, they got more money out of you by replacing the motherboard with another that had the graphics card built in.
This sounds like a processor issue. Try lowering the screen resolution. Right click an open area of the desktop, select properties, click the display tab. In the lower left of the box there is a settings slider, try lowering the settings and see if it gets better.
Dec 15, 2009 | AMD Athlon 64 X2 5200+, 2.6 GHz
I cant do anything about my pc hanging
Since you have not mentioned what type of PC you have so right now all I can suggest is to change the power supply(SMPS)and refit the RAM after cleaning the contact points..................sodeep
May 01, 2009 | Computers & Internet
Hang up during playing games even the games has lower requirements.
it might be a prob with your OS. It is best to reinstall windows
If u have a AGP motherboard then its quite old technology i recommend get a new computer
Oct 07, 2008 | ASUS P5PE-VM Motherboard
System is being hang at any moment even in bios screen. I have changed RAM also. But the same problems is occurring. what should i do ?
It seems that your motherboard is totaled. You are going to need to replace it. If you have a pre-built computer then the motherboards are proprietary and you will need to get one from the computer distributer. If you have a custom build PC then you can just order a new one off a website like If you buy a new motherboard you may also have to buy a new processor that is compatible with it. If you know what type of processor you already have then you can buy a motherboard that will support it.
Feb 22, 2008 | Intel D845GVSR Motherboard
What type or modelof motherboard did you use now?
Feb 19, 2008 | Intel Pentium III, 800MHz (229725001)
EliteGroup P4VMM2 Motherboard Logo
79 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
