Question about ViewSonic PJ510 Multimedia Projector
My hp laptop plays the dvd but the viewsonic does
My hp laptop plays the dvd but the viewsonic PJ510 does not detect the rgb signal. Please help?
Thanks
  • 3,037 Answers
Try pressing the "Fn" function key, holding it and pressing a key on the laptop in the "F" series that either says CRT/LCD or something similar to get it to show up on the projector. Let me know if you are still having trouble.
Benjamin
Posted on Jul 11, 2009
Video source not detected by dvd recorder
If the recorder accepts RGB see that your source puts out RGB or video. If the recorder is set to S-video the source must send an S-video signal. Match the signals.
Aug 14, 2013 | Televison & Video
The picture is blue when I play a dvd. I recently connected it to a new Vizio TV. The other tv it was connected to gave us a good picture.
Check your connections for faults, also some connections on TV's are for RGB inputs, so you might have to try another connector or if you can switch the DVD's output to RGB etc.
Apr 04, 2010 | GoVideo DVR4000 DVD Player/VCR
Projector will not detect a Dell computer
Computers do not generally send an RGB signal, you should be connected via a VGA cable between the projector and the computer. The input menu on the projector should be set to VGA. The output of the computer should be equal or lower to the maximum resolution of the projector.
Jan 29, 2010 | ViewSonic PJ551 Multimedia Projector
I have a viewsonic pj510 that has worked fine for months.
Hi Leo7
Try right clicking on your desktop and going to properties.
Then go to advanced and check in the window with the two screens in it if the secondary screen/monitor is attached - it should be attached.
May 21, 2008 | ViewSonic PJ551 Multimedia Projector
Using TV as computer monitor
Same problem!!! Inspiron E1505 connected to a year old LG 47" 1080p lcd. My rgb used to work fine, plug and play with my pc. No luck with my laptop though. I've tried setting up duel monitors, updating all(atleast I think all) of my drivers, and rechecking all connections!! Please Help.
May 06, 2008 | Televison & Video
My Hyundai DVD player plays DVD's in Black and White or in a greenish tinit. Freeview, videos all okay. Any ideas?
On the DVD Player, there maybe somewhere where you can change the output to the television (Scart) from RGB to Component or Composite-mode.
RGB causes some displays which cannot handle the RGB signals to black and white.
I hope this fixes your problem.
Finally, some TVs designed for PAL cannot handle NTSC discs played through them. It causes the display to also go Black and White. If this is the case there is nothing you can do except change the display/TV.
Don forget to rate.
Mar 17, 2008 | Hyundai ImageQuest DVD 320 A DVD Player
Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Mar 10, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Cant play a dvd on laptop hp pavilion dv4000
I assume it will not play Store bought or rental dvd's.
Try buying a cleaning disc and see if that helps. Other than that the drive would need taken apart and cleaned to see if that fixes it.
It could also be an electronic failure, in which case it would be cheaper to replace the drive.
Hope that helps...
Geno
Mar 04, 2008 | HP Pavilion dv4000 Notebook
Green Picture
The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
Jan 13, 2008 | Daewoo DV-6T955B DVD Player/VCR
ViewSonic PJ510 Multimedia Projector Logo
139 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
avlakhira366
Level 1 Expert
Miguel Luiz Martins
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
