Question about Clarion DRX-9675Z CD Player
Wireing harness. hi,i need to know the colours and order off the loom for the back of the head unit.it has 8 pins in it.any help would be appriciated.please email me a picture to..stilts@xtra.co.nz.
    Brigadier General:
  • 6,966 Answers
Hi diamante,
For your reference, pls see below image.
Further, here is a page of the official Clarion standard wirings and their color codes.
Here is a source of the connector for your reference. You don’t need the speaker connector since your unit does not have any built-in amps.
Additionally, if your vehicle’s wiring connections are not of the ISO-standard type or if you just want to verify, please follow this link for the installation adapters you may need to fit your Clarion DRX-9675Z CD Player to your particular vehicle.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Nov 15, 2007
2005 TOYOTA COROLLA WANT TO WIRE UP THE SEVEN PIN TRAILER PLUG TO MY TOYOTA 2.0 D4D LITRE COROLLA
the secret here is to buy a trailer harness for the vehicle ( available from most tow bar supply and fitting shops )
it is a set that just plugs into the existing harness at the rear light assembly ( piggy back arrangement)
from there you wire the male and female plugs as per the color code that is on the paper that comes with the units
saves cutting into the car harness and causing real electrical problems
Jul 03, 2016 | Toyota Cars & Trucks
I need a wiring diagram for a Mitsubishi Stereo DX-262AL. I want to replace it with a Clarion CD stereo, which I need to "marry" to the existing DX-262AL car loom. Any help much appreciated.
Option 1: If you haven't purchased any components yet.
If your Mitsubishi still has the original OEM (factory) wiring loom, then the newest method of connecting an aftermarket head unit (i.e. Clarion) is by using a 'snap-on' adaptor harness which eliminates the need for any cutting/joining/soldering.
The adaptor you want is the Mitsubishi-to-Clarion type: one end of the adaptor has the Mitsubishi (female) plug and the other has the Clarion (female) plug.
These adaptor looms can be purchased from most automotive accessory shops, or you can purchase very cheaply online from Ebay.
Check this link (this is the Clarion MAW2-16 adaptor for 1995-2004 Mitsubishi vehicles) @ USD $1 + $11 shipping (Note: the Year of your vehicle will determine which harness you require):
http://cgi.ebay.com/CLARION-MITSUBISHI-FACTORY-WIRE-HARNESS-ADAPTOR-95-2004-/370521783457#vi-desc
Option 2: the hard way
If you REALLY want to do it the hard way and start cutting wires, then here is the wiring colour codes:
EARLY MITSUBISHI AUDIO CONNECTORS:
LATER MITSUBISHI AUDIO CONNECTOR (SINGLE TYPE):
I trust this answers your question? :-)
"If this has helped you, please take a moment to rate this solution. As always, I do appreciate personal testimonials from Fixya customers, after I have offered technical support. Thank you."
Sep 08, 2011 | Car Audio & Video
I HAVE A KENWOOD DNX9980HD 20 PIN HARNESS THAT CONNECTS TO THE KENWOOD HEAD UNIT. I ALSO HAVE AN AXXESS ASWC (STEERING WHEEL CONTROL MODULE)20 PIN HARNESS THAT CONNECTS TO THE AXXESS ASWC. THE AXXESS...
HI,
If you make a close verification on the back side of kenwood DNX9980HD 20 PIN HARNESS then you can see a Light Blue wire with Yellow stip ( BLUE/YELLOW) on it with a identification mark as "Remote cont". You have connect this wire to the Brown wire with white strip (BROWN/WHITE) from the 20 PIN HARNESS of AXXESS ASWC . There wil be a brown wire also from this 20 PIN HARNESS of AXXESS ASWC, leave it free insulated. It will not use with kenwood radios. You have to check for LIGHT BLUE with WHITE strip. There is also two other blue wires of which one with white strip. You hve to choose the light blue wire.
ok
Aug 06, 2011 | Car Audio & Video
Fitting single towbar electrics, Hyundai Coupe 2.0 2004 (Tiburon)
Hi There. Im not sure where you are but this is the sequence for the UK< Hope it helps.
here are the 7 cable locations and pin numbers.
Pin 1 Yellow L/H Direction Indicator
Pin 2 Blue Rear Fog Lamps
Pin 3 White Earth Return
Pin 4 Green R/H Direction Indicator
Pin 5 Brown R/H Tail & No, Plate Light
Pin 6 Red Stop Lamps
Pin 7 Black L/H Tail & No, Plate Lights
I found the easiest way to locate the correct wires in the loom is to turn on the lights required and use a circuit tester and splice into the main loom where you have enough wire to play with. Try not to cut the loom as it only causes more problems with bad connections and joins.(
Good Luck
Apr 16, 2010 | 2003 Hyundai Tiburon
Aftermarket Stereo connection
hi there
if you matched all the wires from the harness to the kenwood deck and its not working don't worry you just missed the last step........(all wires attached that a colour coded connected)
simply turn your car on.........now on the front of the kenwood deck there is a SOURCE button with all units it could be a (S, SRC, Power) hold the source button down till your kenwood unit powers up ..........if your unit still doesn't work check the fuse on back of kenwood unit should be a 10a fuse (blue) if the fuse is fine put the unit back in dash..........now check the fuse panel on driver side dash with the door open you will see this panel pull it off (some describe the fuse panel as looking like an air vent but its not its a handle to open) now on the panel that you just pulled off there is a fuse diagram on the inside look at it find radio fuse it will be a (blue fuse) located in the top row of fuses check it if blown replace and unit should work.............if this doesn't solve the issue than its a (sneaky) fuse not to many people know about if you pop the hood of your car there is a black plastic panel located just below the battery pins and just above the driver head light (usually black box with yellow writing on it......in this there are mini fuses check all of them do not touch the black relays in there just the small tiny fuses the fuse you will look at should be yellow 20a (this fuse is closest to engine and comes after the abs relay if you look inside the lid you took off it will have fuse locations cant remember which one it is for sure but check them..........now see if your kenwood unit powers up if not the last option is to ground to the black wire from back of kenwood unit to metal frame.............this last part is also done if your unit does power on but your car lights don't work if this happens ground the kenwood unit to the frame of car and open up fuse panel on driver side dash replace the blown fuse for lights or radio (make sure the kenwood unit is grounded to the frame before replacing the fuse in dash panel............if this doesnt help you than i would assume the kenwood deck needs to be repaired by kenwood.......
good luck
hope i was able to help and sorry this list is so long
Feb 26, 2009 | Car Audio & Video
Wiring diagram for cd player
that actually is not for a head set, tha tis for a remote, you plug in the remote that you can buy from an audio store and mount it on the dash....
Nov 26, 2008 | Clarion DB175MP CD Player
Kenwood 8pin harness
looking at back of 8 pin harnes, with wires facing you and tab facing up, left to right,
top
plugged into head unit i----------- i
______________________| |___________________________
| 1st pin, - blank | 2nd pin - Black wire | 3rd pin blank | 4th pin blank |
| 5th pin - yellow | 6th - pin blank | 7th pin- green| 8th blank |
Sep 27, 2008 | Kenwood Excelon DDX-7015 Car DVD Player
Fuse box
Wiring relays and connections – all modelsRelays (typical)
1 Vacant
2 Intake manifold preheating relay (carburettor models) or fuel
pump relay (injection models)
3 Seat belt warning system relay
4 Gearshift indicator control unit
5 Air conditioner relay
6 Dual tone horn relay
7 Relay for foglights and rear foglight
8 Relief relay for X contact
10 Intermittent wash/wipe relay
11 Rear window wiper relay
12 Turn signal flasher or trailer towing warning relay
13 Seat belt warning system (interlock) or rear window, driving
lights and oil pressure warning relay
14 Window lift or seat belt warning system relay
15 Headlight washer relay
16 Control unit for idling speed increase
17 Fuse for rear foglight
18 Control unit for coolant shortage indicator
19 Thermo fuse for window lifters
20 Switch unit for heated driver’s seat
21 Switch unit for heated passenger’s seat
22 Switch unit for overrun cut-off
23 Vacant
24 Vacant
Relays are symbolised as a number in a black box
Not all relays are fitted to all models
Connections
A Multi-pin connector (blue) for dash panel loom
B Multi-pin connector (red) for dash panel loom
C Multi-pin connector (yellow) for engine compartment loom left
D Multi-pin connector (white) for engine compartment loom right
E Multi-pin connector (black) for rear wiring loom
G Single connector
H Multi-pin connector (brown) for air conditioner or wiring loom
K Multi-pin connector (transparent) for seat belt warning system
loom
L Multi-pin connector (black) for lighting switch terminal 56 and
dip and flasher switch terminal 56b (carburettor models) or
multi-pin connector (grey) for dual tone horn (injection models)
M Multi-pin connector (black) for lighting switch terminal 56 and
dip and flasher switch terminal 56b (injection models)
N Single connector for separate fuse (manifold heater element)
P Single connector (terminal 30)
R Not in use
Fuse colours
Blue 5A
Green 30A
Red 10A
Yellow 20A
Jul 17, 2008 | 1987 Volkswagen Jetta
Connecting To Auto Harness
Most Sony head units follow the ISO standards in its wiring and connector pinouts.
A Sony CDX-S2000 would be using the below listed wiring:
Yellow - +12V Constant Power (such as the + terminal of your battery)
Red - +12V Switched Power (such as the ACC of the IGN switch)
Blue - Power Antenna
Blue/White - External Power Amp Turn-on trigger
White - Left Front Positive Speaker Wire (LF+)
White/Black - (LF-)
Gray - Right Front Positive Speaker Wire (RF+)
Gray/Black - (RF-)
Green - Right Rear Positive Speaker Wire (RR+)
Green/Black - (RR-)
Purple - Left Rear Positive Speaker Wire (LR+)
Purple/Black - (LR-)
In some models, Sony would have several versions of the connectors depending on the region the unit was intended for use, 10. 16 and 18 pins. The connector (loom) would have to match what your version has. They are readily available from most auto stereo stores and on line. You can try here or here .
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Thank you for using FixYa.
Mar 07, 2008 | Sony CDX-S2000 CD Player
The harness on the back of the head unit
with locking pin facing bottom of unit plugged in its
l to r top blank green blank yellow
l to r bottom blank blank black red
Dec 20, 2007 | Kenwood KVT-617DVD Car DVD Player
Clarion DRX-9675Z CD Player Logo
296 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
