Question about EliteGroup P4VMM2 Motherboard
On board graphics p4vmm2
I disabled my onboard graphics and now i cant turn them back on i dont know what jumper setting s to use can somen 1 please help
  • cube2600 Nov 15, 2007
    i removed the battery from my mot.her board and reset the cmos with the jumpers but but my onboard graphics wont turn back on. should i flash my bios and if so where can i get a working flash tried going to my mother boards site but the flash doesn't seem to .my bios is set properly.i heard of a program that might work.Winternals.Erd.Commander.2005.have u heard anything about this
  • 71 Answers
This is the manual for your motherboard. Page 13 shows you which jump you need to reset to clear your BIOS. The jumper appears to be labeled JBAT1.
Hope this helps!
Posted on Nov 15, 2007
  • 87 Answers
Well if ur problem is still not sloved install the agp u removed den go to bios n turn back it on and den remove da agp :) might b helpful
Posted on Nov 17, 2007
Disable onboard graphics of my PCChips M825LU motherboard?
Yes its a BIOS setting that you have to change. Usually you change from on-board to AGP settings or plug the graphics card in, take out the motherboard battery and the power cord from the back, leave it for 20 minutes and put them all back again.
This will reset the BIOS and should auto detect the AGP graphics card. You will however need to set the date and time but you can do that from Windows.
Jun 28, 2010 | PC Chips Computers & Internet
Pci express will not work
Your N9600GT provides two HDMI out puts for dual display.
Even though you are currently only using one HDMI. Switch your monitor cable to the other HDMI out put. See if you now have display.
Also while in the bios allow, Page 2-27 in manual, Allocate IRQ to PCI set to [Yes]. Page 2-24, Internal Graphics Mode Select, [Disable]
Oct 07, 2009 | ASUS P5GZ-MX Motherboard
Want to disable onboard graphics to install and use pci vga card
During the initial boot sequence (as soon as you turn your PC on), try pressing <DEL> button (or F2 or F10 - you will see info on the bottom of the screen stating something like "Press _____ (del, F2, F10) to go to Setup..."
This will take you to BIOS, main setup panel for your PC.
There you can find and option for switching your main GFX card.
Options will be something like: onboard, pci, agp. You should choose
Try doing this after you insert your new PCI gfx in your computer.
Good luck,
Jun 01, 2009 | EliteGroup P4VMM2 Motherboard
I have an emachines etower 433i with onboard video. I've installed a separate pci video card, but I don't know how to change the jumper settings on the motherboard to disable the video chip. On the...
Go into >my computer>properties>device manager>graphics.You should be able to disable your on-board graphics there. Be sure your computer boots from the new card before you do this.
Dec 17, 2008 | Computers & Internet
Were are the jumpers to disable the on board videofor aopen mx3w pro-E
Why do you need to disable the onboard video??
If you have added a new graphics card it should automatically select this new card.
If it doesnt, you can go in to the bios and disable the onboard graphics card from there.
For example, Onboard graphics can usually be refered to in the bios as PCI, so if you've added an AGP card or PCI-E card then you would just need to select either one of these from the bios menu.
Not sure what bios your using but it may even have ann option to disable onboard graphics.
Oct 23, 2008 | AOpen MX3W Pro-E (91.88210.241)...
Pv4mm2 trouble
I've the same problem, and I've done alot of google searching, but coming up with the same few articles only. From what I've found out, the higher-end versions of the P4VMM2 do support a 533 FSB, but the older versions, like 1.1a do not, seem capped at 400mhz. My motherboard does not have ANYWHERE a version # on it, I found through trial and error that it must be a 1.1a , as 1.3 makes my onboard NIC disappear. Transversly, the 1.1a manual states 2 things: 1 - it supports up to a 400mhz, 2 - jp1a and jp1b are 'physically there' and 'supposed' to switch from 100 to 133mhz, but when I PUT them in the opposite order, the pc won't boot, id be interested in knowing why btw, no answers yet. And so, it leads the question "why are there jumpers for 133mhz setting, if the darned thing doens't boot at this setting???'. Perhaps it IS capable of it, and there is another problem?? I've asked around n been told possibly switching to DDR ram, instead of SDRAM may allow the speed to up, as the old ram can't handle the speed?? I've also read some very brief article which stated your 'pci / agp ratios' must be correct, does this mean there is some other settings you need, to activate the 133 n make it boot? Either way it's very frustrating having my 2.66ghz, running at 2.0 ghz.
The quest goes on.
Jul 10, 2008 | EliteGroup P4VMM2 Motherboard
For user BIOS21 & julio1963,
How to enable you're (Add-in AGP video card) & disable the onboard, integrated S3 graphics UniChrome 2D/3D PCI graphics card.
Enter you're bios. Open you're user manual to page 3-13. Integrated Peripherals. Go to, Init display first. Set to AGP.
(Not to PCI). That is all you need to change. The MSI bios will than see you're add in AGP card & automatically disable the PCI S3 graphics, (Onboard) card.
If I can help you further, feel free to post here.
Please, each user's vote this issue as a fix, if this helped you to get you're bios to see you're new AGP graphics cards.
May 31, 2008 | MSI KM4M-L Motherboard
You should be able to turn it off by booting the pc up into the Bios and changing your video settings to AGP.
May 17, 2008 | EliteGroup P4VMM2 Motherboard
Disabling Onboard Video
no you dont need the jumpers or some from there...just before booting your OS,go into the bios field.
there you will find the option you must set to disable.
the exact point youll find it I cant tell you because bios are different from board to board..depending of the manufacturer..just surf the bios,youll find it and disable it
good luck bye
Feb 07, 2008 | Biostar P4VMA-M Motherboard
turning on your computer, press either F8 of Del to enter to the BIOS Setting, search for the graphics/video and change it to AGP
Nov 16, 2007 | EliteGroup P4VMM2 Motherboard
EliteGroup P4VMM2 Motherboard Logo
243 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
