Question about Cameras
Once my camera is on it focuses and then just shuts
Once I turn my camera on it tries to focus for a few seconds and then the camera just turns off.
  • 217 Answers
It might be due to discharged batteries.. You need to replace the batteries with the new ones. If the problem persists let me know.
Posted on Jul 11, 2009
When filming or not the picture becomes blurred for a few seconds every few minutes. Please can you help.
It sounds like it's simply auto-focusing. When you're filming and the camera auto-focus sensor detects a new focus object, it will attempt to refocus on the new object. In lower light situations, this may take longer for the sensor to read the new object. The only way to resolve this is to turn auto-focus off (if your camera allows it). If your subject area remains in the same plane of focus, you shouldn't have any focus issues. If it changes, however, you will have to manually refocus to the new plane, just as you would with a manual camera.
Hope this helps!
Mar 02, 2011 | Cameras
My camera turns on but it won't focus on automatic and when I press the button to take a picture it won't take one on manuel or automatic.
There may be a few things preventing the camera from taking a picture. I don't know the lens you are using but by chance does it have an auto/manual switch that has been switched to manual? Also make sure the lens is locked in position. The camera won't take a picture unless it has focus in the auto focus mode, this is normal. What are you trying to focus on? The camera auto focus system will search and fail to auto focus on surfaces that have little or nor contrast. For example glass, chrome, a blank wall, water, blue sky. Other conditions that auto focus fails is being to close to your subject, heavy fog, a dim lit subject, available light and night photography. Once the little green confirmation light comes on the camera has focus and will operate as it should.
Nov 27, 2010 | Canon EOS Rebel XS 35mm SLR Camera
My camera (a Canon PowerShot SX10IS, if it matters) has this tendency to move in and out of focus when I'm using the video recording feature. For example, I can start the video by filming a stationary...
I have the same problem with the same camera. I believe the problem can be solved by turning the knob to MOVIE mode, then push the menu button. When the menu screen pops up. Go to the "camera" tab. It should be the first tab to your far left.
Once you are at this tab, scroll to the very first option which should be the AF FRAME option (Auto Focus Frame). Select "CENTER" for the Auto Focus and do not select "face detect." I think when it is in face detect mode it is sometimes searching for the persons face. If you just leave it in CENTER mode, then it just fixes itself in the center. This is what I am going to try. I think it should work.
Hope that helps.
Peace
Jun 23, 2010 | Canon PowerShot SX10 IS Digital Camera
Canon camera SX10 IS doesnt turn on
this is a dead battery issue. the batteries were probably already discharged.
Jan 25, 2010 | Canon PowerShot SX10 IS Digital Camera
Camera wont focus or stay on
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
May 25, 2009 | Olympus FE-340 Digital Camera
Canon G9 digital camera
There are two stages to the shutter release. The first stage is the focus stage pressed half way down and the second stage is the actual shutter release. Always press the shutter half way to get the camera focused first then press all the way down when the camera is ready to take the shot. Check to see how the settings are with regard to how it focuses (9-point, face recognition, etc). When the camera focuses you should get a green box or multiple green boxes depending on your settings. That tells you the camera is ready to take the picture. Pressing the shutter all the way down at once from the beginning will cause the pause you describe since the camera has to first focus then shoot the picture. Depending on the subject or subjects the camera may take a second or two longer to focus. With good lighting my G9 focuses pretty fast. Hope this helped.
Aug 31, 2008 | Canon PowerShot G9 Digital Camera
Olympus C-765 does not focus
Dear Benjamin,
I also own an olympus c765 and was wondering how to use the manual focus option when I came across your post. Actually I have been wondering whether manual focus is of any use in an olympus c765 because the manual does not talk anything about it.
However, I just found out that there is a way of activating/deactivating manual focus. Here it goes:
1. Turn the camera on
2. Switch to any mode - portrait/landscape etc
3. Press and hold the 'OK' button on the centre for a second until you see a MF/AF option on the screen
4. Switch to MF and focus on any subject by pressing the up/down keys.
Most likely, your camera has been turned to Manual Focus option, which is why it is not focussing any more. Follow the steps above and turn it back to Auto Focus option and let me know if your problem gets solved.
Regards
Aug 30, 2008 | Olympus Camedia C-765 Digital Camera
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Zooming
The exactttt same thing happened to me. I think i still have a warranty on it, and every body has been trying to help me, but it seems the camera is just retarded- and just needs to be replaced
Jan 03, 2008 | Olympus FE-280 Digital Camera
FE-280 Wont Focus and Shust Off
I have the same problem, but my display doesn't show anything. It is just black.
Dec 10, 2007 | Olympus FE-280 Digital Camera
Cameras Logo
19 people viewed this question
Top Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
