Question about Cameras
I cannot open the ac adaptor ''door''
I just bought a samsung wb500 digital camera. I have to charge the battery before I use it, but cannot open the ''door'' to the ac adaptor slot .... so I cannot charge the battery
  • birchley Jul 11, 2009
    Thanks, it worked. Problem was ... no manual with the bought product, but I found a site and downloaded it. Once I knew for sure I used my army knife to prise it open because it was pressed in so tight. And I agree about the manual, it uncovers a wealth of capability Id never have realised.
    In case anyone else needs the link, go from here http://www.dphotojournal.com/samsung-wb5...
  • 217 Answers
See the user manual that comes along with the camera.. reading the manual may take some time but it is very useful and handy in such cases. You will come to know about many beautiful features of your camera and would be able to do a lot of experiments.
Posted on Jul 11, 2009
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Download driver for samsung wb500 to windows 8.1
For Windows 7 and 8, no drivers are needed. Yes your computer installs drivers but you get them from Microsoft direct.
Only equipment, certified by Microsoft, is allowed on these operating systems. The drivers are free. When you conned the camera to the computer, Windows will goto the Microsoft database, and get the correct driver. The software to manage the pictures, or to transfer the pictures from the camera to the computer you have to install from the CD that came tithe the camera. When you lost the CD please goto the samsung website and get the software (It will be free of charge for camera owners)
Jul 25, 2014 | Samsung HZ10W / WB500 Digital Camera
How do I charge the battery for this L200 camera? My daughter received this camera for Christmas, and I can't find anywhere the instructions for how to charge it! Please help! Thanks! Hollye F.
you have the usb cable and adptor right??connect the adaptor and usb then insert it to the camera then plug in to the ac line..but takenote.,the battery was inserted tot he unit..
Feb 20, 2011 | Samsung L200 Digital Camera
I've lost the cable to charge my camera:WB500 How can I get an other one Thanks
From page 7 of the user manual for the WB500, it states that you have to contact a retailer in your country in order to buy the appropriate cable for your country's power system.
Dec 30, 2010 | Samsung HZ10W / WB500 Digital Camera
HEY ! my Samsung WB500 won't turn on...I've just bought it, well it was a present but its brand new AND i've charged it and everything, but it won't turn. need help ASAP.
I just had the same problem. All I did to solve it was take the battery out, scratch the contact on the battery (CAREFULLY) and put the battery back in and now it works. The contacts must have oxadised a little. This is not good as far as quality is concerned but it was an easy fix.
Hope this helps!
PS I love my WB500!!!
Nov 27, 2010 | Samsung HZ10W / WB500 Digital Camera
My camera light comes on when i press the on/off button and the lense comes out all the way but then goes in abit, and beeps twice, i then click the power button again and the lense goes in, beeps again...
The problem you describe is power related, and is usually caused by one or both of the following:
1. Your batteries may need to be replaced. Batteries get old and lose their ability to accept and hold a charge, so they may be very low even with an overnight charge. Check the battery power with a voltmeter if possible, but batteries often need replacing if they are a year or more old.
2. Corrosion buildup on battery and camera contacts is a common problem, especially if a camera is idle for long periods. Remove the batteries and check all contacts for a white, green or blue buildup. Even if you don't see anything, wipe the battery contacts and the camera contacts firmly with a clean dry cloth. Heavy buildups, if present, may require cleaning with a fine wire brush, steel wool, or sandpaper. After cleaning make sure that there is no buildup residue in the camera's battery compartment. Then install and charge the batteries.
Other possibilities, although rare, are problems with the charger or the camera's power circuitry. You can check the charger output with a voltmeter, but troubleshooting the camera's circuitry requires a professional camera shop.
Bill B.
Nov 01, 2010 | Samsung HZ10W / WB500 Digital Camera
My camera samsung wb500 cannot be recognized by a computer. When plug it in to the computer via usb cord it is recognized by the pc. The light on the camera flickers but nothing happens. Thus I am not able...
I have the same problem with my WB500. From the start I haven't been able to charge it via the computer or down load photos. I solved the problem by buying a card reader and a separate battery charger. I tried to get the problem resolved by Samsung, but with no luck, so solved it my way instead
Sep 04, 2010 | Samsung HZ10W / WB500 Digital Camera
I cannot upload photos from my wb500 samsung camera and would like some help on how to do this
Having gone over a month without a response, I assume my suggestion solved the problem.
Jul 09, 2010 | Samsung HZ10W / WB500 Digital Camera
When i go to charge my kodak M863 camera (in the wall or by USB) the green light flashes and then the red light blinks 3 times. please help this is the first time charging my camera.
You can used the USB cable to charged the camera, But some of the M863 camera will not take charged usign the USB cable., I strongy suggest used the AC adaptor just make sure the AC adaptor is 5V ac adaptor it will only charged using the 5V adaptor., About the flashing green it indicates camera is charging just wait for the solid green light it means it fully charged
You may purchased also a special charger for your battery(KLIC-7001)- cahrer model is K8600-C. i think the price of this charger is around $29.00
Nov 14, 2009 | Kodak EasyShare M863 Digital Camera
No remote control
call samsung customer service listed in your manual
Oct 25, 2009 | Samsung HZ10W / WB500 Digital Camera
How to charge My Samsung L730
Here is the owners manual for your camera. Pages 13-15 detail how to connect it for charging/recharging the battery.
http://downloadcenter.samsung.com/content/UM/200802/20080221092928218_L830_L730_English.pdf
Jan 09, 2009 | Samsung Digimax L730 Digital Camera
Cameras Logo
Top Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
