Question about NEC MultiSpin ND-1100A (ND-1100A) DVD+RW Burner
XP can't find ND-1100A drive
Hello, my XP PC seems to have stopped detecting that my ND-1100a DVD drive is there. The device manager says its loaded the driver but that it can't find the hardware device. Any advice?
  • 696 Answers
Thanks for coming to FixYa, The problem you have is either a well documented software problem or a failing drive.
Click the below link, then scroll down and click the "Fix It" button. Follow the onscreen instructions, restart when it's done and see if your drive re-appears. If it does, you're done, if it doesn't work then your drive is most likely failed and you should replace it.
www.microsoft.com/kb/341060/
Hope this helps FixYa,
Chris
Posted on Jul 18, 2009
Jumper setting in cpu
Not sure what the CPU has to do with anything! The following might help with CD/DVD drive jumper settings:
http://www.computershopper.com/storage/howto/installing-a-new-dvd-burner4
Jan 03, 2014 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
It no longer burns discs
Try cleaning it with alcohol on a Q-Tip clean the eye that is located in the drive it will be on a slider . If that doesn't work the replace the drive they do go bad after extended use you can Find one at New Egg for less then 25.dollars
Sep 17, 2011 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
Will not read any dvd
make sure the CD or DVD media you isnert is compatible for read/write opeartions
this DVD/RW is 12x40 trasnfer (rate read) and 4x16 write +RW
what format or speed CD media are you inserting ? go to this link to give you a better look at the specs of this NEC product you have
http://support.necam.com/optical/specs/nd-1100a.pdf
if this helped you , please rate me
Nov 03, 2010 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
My dvd rw can't read dvd cd but they can read a cd only
try to go to registry editor and delete upper/ Lower filter. It should resolve the issue
Mar 24, 2010 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
What is the jumper setting as slave?
All drives are different, you have to look on your drive for the pin config
Nov 07, 2009 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
Drive will not stay closed
mechanical problem, switches. hard to repair and you dont get the parts for that
May 03, 2008 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
NEC DVD+RW ND-1100A
This is a single layer drive only. Usually dual layer drives have DL in the form factor so possibly a
NEC DVD+RW DL?
http://www.adamant.com/itemInfo.asp?GotoID=ITEM&PrdAbr=CDVN-3540A&menu=PARTS
Oct 24, 2007 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
Nec dvd + rw nd-1100a
first try a audio CD see if ti reads that fine. then inset a data CD and see if you can see all the files on it. Try a few data and audio CD's. If it has trouble with any of these your drive has gone to the great garbage dump in the sky.
Jun 28, 2007 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
BUS DEVICE RESET FUNCTION
the bus settings may be the settings that have been changed by roxio, if you havent uninstalled the previous burning programme. Try uninstalling any burning programme you have, restart the pc and install the programme you require. If it continues you may need to uninstall the drive, by way of :- my computer>properties>hardware tab>device manager and look down list to dvd/cdrom drives and click '+' sign to your dvd line and right click and uninstall. Restart pc and it will automaticaly install again, ready for use.
May 11, 2007 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
NEC MultiSpin ND-1100A (ND-1100A) DVD+RW Burner Logo
485 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
