Question about Fujifilm Dl-400 Tele 35mm Film Camera Auto Focus Built In Flash Lotc2-65
How do I fix the tele/wide button?
My camera's tele wide button no longer is working. Every time I attempt to push it down it does not work. Is there anything I can do to fix it? I would even be willing to send it to fuji I am just not sure what to do!
    Novelist:
  • 167 Answers
You'll probably need to take it to a repair expert because the internal component needs to be replaced. Because of the age of the device, lack of replacement parts, it will be hard to find someone who is capable of doing it. Might want to consider an upgrade/replacement.
Posted on Jun 23, 2015
SOURCE:
Can the power button be fixed?
You can search online for several providers of OEM replacement remotes.
Apr 28, 2014 | Sharp Ga035sb Remote Control
Sony Cyber-shot DSC-H5 Digital Camera power button does not work
In today's cameras on off button only give a pulse to processor to switch on.actually camera is on all time technically.only screen is off.Your problem may be flex connection to main board has failed. The group connector for on off, click, Tele, wide, all together forms one connector. Whole part to be replaced by camera technician to save your camera.
Sep 30, 2017 | Sony Cyber-shot DSC-H5 Digital Camera
What do the letters w and t at top of camera back mean
These mean Wide and Tele, for the zoom. There should be a rocker switch nearby that operates the zoom lens. You don't say what camera it is, so I can't be more specific.
Feb 04, 2011 | Cameras
Stylus 730 /7.1 megapixel turn on power lens remains open screen shows ZOOM ERROR HAPPENED WHEN USING THE WIDE/TELE BUTTON
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Sep 10, 2010 | Olympus Stylus 790 SW / µ[mju:]790SW...
I have the SVP t600 hd and i can not figure out how to look at the pictures I have taken. I have misplaced my user manuel, can you tell me where I might find a user guide on the internet?
Simple operation guide for SVP t600 HD digital camcorder
press the video/photo button to select which type of files to access, video or photography
then press the button marked with the play (triangle) symbol.
Doing this will access the photos or video on the installed sd card.
you can also plug it into your computer by USB, turn it on and it appears as a HDD in my computer.
menu is found by pushing the tele/wide button in,
menu control is by pushing t/w button up or down and in to select. the rest is on screen.
Jun 19, 2010 | SVP HDDV T-600 HD Camcorder
Problem with digital concepts teleconverter
The SX1 has an amazing 20X optical zoom. The teleconverter will allow to get pictures if the camera zoom is not fully on 20X. It means that you can't get a full 40X zoom images, but a 30X maybe. I don't why canon has this problem.
Jul 03, 2009 | Digital Concepts (1352T) Lens Converter
Lens Error and Proper switching on Problem
Same problem for me. Try below one. Its working!!!
Press the power-on button, and at the same time Press and hold the shutter button down
Mar 11, 2009 | Cameras
Wide/telescopic lens stuck
This might be the problem:
http://www.instructables.com/id/Repair-Stuck-Lens-on-Panasonic-FZ5/
Oct 23, 2007 | Panasonic Lumix DMC-FZ8 Digital Camera
Adapter ring cover problem
Maybe the adapter ring release button is stuck after you pushed it in to release the cover. Try giving it a good flicking until you are sure it has popped out.
Jan 27, 2007 | Fuji FinePix E550 Digital Camera
H1 - is this normal ?
I haven't ever noticed anything like that with my camera. There is a slight amount of play on my lens though.
Sep 12, 2005 | Sony Cyber-Shot DSC-H1 Digital Camera
Fujifilm Dl-400 Tele 35mm Film Camera Auto Focus Built In Flash Lotc2-65 Logo
274 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
