Abs light on while driving after having a wheel hub fitted on vauxhall vectra 03 any ideas why???? thanx
    Champion:
  • 239 Answers
Bad sensor
Posted on Sep 04, 2009
Park my vectra 02 down hill its hard move
When I had a vectra I had a problem when I parked it facing up hill or driving up steep hill kept cutting out to solve this I had to get a new fuel tank fitted
Jul 09, 2014 | 2003 Vauxhall Vectra
My abs light came on ,i have avauxhall vectra,what do ioneed to do
check your brakes, brake fluid levels, brake pads
Jun 26, 2014 | 2003 GMC Envoy
Vauxhall vectra problems
when on full throttle on my vectra sri turbo the engine electrics warning light comes on and the car goes into limp mode
Jan 13, 2014 | Computers & Internet
Why is my abs light on in my 03 chevy? and on the passanger side the front tire is roaring really bad when i drive, please help
Ok, there are sensors on your front wheel hubs. This could easily cause the abs light to turn on. The loud noise could easily be your wheel hub going bad. Easiest way to check, jack up the front of the truck, grab tire, shake back and forth and up and down. Same amout of play each way? You're wheel hub is bad.......
Aug 27, 2010 | 2003 Chevrolet Tahoe
Shimmy in wheel when braking lightly
Check what sensor type is fitted - i.e. can run off hub magnet ring, or may be older type peak/trough driveshaft ring that runs next to wheel abs sensor. If you've changed the hub parts then the sensor or sensor wiring is the best place to start with. You may need use of a diagnostic tool to check the wheel sensor works when spinning the wheel.
May 08, 2010 | 2006 Pontiac Grand Prix
03 Yukon Denali Traction Control/ ABS Problems
my 2000 yukon has the traction control light on and the abs light on any anwsers?
Jul 31, 2009 | 2003 GMC Yukon Denali
Speedo not working and tc and abs lights on
2000 vectra the dash light and fog lights dont work can you help
Nov 23, 2008 | 1997 Acura CL
Buick rendevousz headaches
I own the 2002 Buick Rendezvous CX and I've encountered the same problems listed here. The ABS / Traction Control Lamp stays on and was throwing a code for the left wheel speed sensor as well as an anti-lock brake code (both in the wheel bearing hub assembly). I replaced the left and right front wheel hub assembly yet this did not eliminate the abs codes.
Ultimately, I traced this problem to a break in the wire that leads to the left hub assembly. Although the sensor was properly connected, the wire (which is encased in a plastic housing) was broken. This is the wiring which leads from the abs wiring harness under the hood down to the left wheel abs sensor.
I would suggest that you simply remove the left wheel and inspect the wire that leads to the abs sensor (there is only one wire on each wheel). Mine literally fell apart when I removed the plastic housing around the wire. I spliced the wire together and put it back in the plastic housing. After this, my abs codes disappeared and my anti-lock brakes began working again!
This is a simple fix that many people spend $1000 + on by replacing the hub assembly which does not fix the problem.
Aug 20, 2008 | 2002 Buick Rendezvous
Computers & Internet Logo
169 people viewed this question
Alun Cox
David Payne
David Payne
