Watches Logo
j
joao almeida Posted on Jun 23, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to set a watch? - Watches
David Payne
Level 3:
Top Expert:
  • Master 14,162 Answers
  • Posted on Jun 23, 2015
David Payne
Master
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2995996
Points
455836
Ashley Perez
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 14, 2015
Ashley Perez
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
727
Points
rodilyn
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Jun 29, 2015
rodilyn
Contributor
Level 1:
New Friend:
Answers
16
Questions
Helped
2013
Points
47
Step 1: Punch the Right ButtonsCheck your watch for a"Mode"function.A typical digital watch can be set with buttons visible off the watch face, either to the left and right or with four of themsurrounding the face. The button may instead be labeled "Set" or "Adjust" or something similar."Mode"often will tellyou what functions are available. Press"Mode" two or three times or according to your instruction manual, until the display blinks.Step 2: Set the Hour and MinutesContinue setting the time.The Stauer Magnus digital watch, for example, has four buttons: Stop/Start, Reset, Mode and Backlight. Press "Mode" three timesto start the process until the display blinks; "Reset" selects the hour, while hitting "Reset" twice selects the minutes.Hit "Mode" to select the time when you have it adjusted.Step 3: Set an Alarm or TimerSetting the alarm on the Stauer Magnus involves hitting "Mode" twice, and then selecting a combination of other buttons. It'sdifferent for every brand-- there's almost a mystique to learning the intricacies of your watch -- so check your instruction manual if it isn't self-evident, and hang on to those instructions in case you don't use them often.
1helpful
How to set the time on a Dakota one button watch
To set the time on a Dakota one button watch, you will need to follow the instructions in the user manual that came with the watch. If you do not have the user manual, you can try the following steps:
  1. Press and hold the button on the top right side of the watch: Press and hold the button until the time display appears.
  2. Set the time: Use the button to set the time. The specific sequence for setting the time will depend on the make and model of your watch.
  3. Exit the time setting mode: Once the time is set, you will need to exit the time setting mode. The specific steps for exiting the time setting mode will depend on the make and model of your watch.
It is important to note that the steps for setting the time on a Dakota one button watch may vary depending on the specific make and model of the watch. If you are unable to set the time using the steps above, it is recommended to refer to the user manual or contact Dakota customer support for assistance.
If you have a "his and hers" set of Dakota watches, the steps for setting the time on both watches should be the same. You can use the steps above to set the time on both watches.
Need instructions on a digital jaga watch WR50M on how do you set the date
To set the date on your Jaga digital watch with the WR50M model number, you will need to follow the steps for setting the date on your particular watch. Every watch is different, so the specific steps will depend on the make and model of your watch.
Here are some general steps that you can follow to set the date on a digital watch:
  1. Locate the stem (the button on the side of the watch) and press and hold it until the display begins to flash. This indicates that the watch is in time-setting mode.
  2. Use the stem to cycle through the different settings, such as the time, day, date, and year.
  3. When you reach the date setting, use the stem to adjust the value to the correct date.
  4. Once you have set the date to the correct value, press the stem to exit the setting mode.
If you are unsure of how to set the date on your watch or if you are having trouble, you may want to consult the manual that came with the watch for more detailed instructions. If you do not have the manual, you may be able to find a copy online or you can try contacting Jaga customer service for assistance.
Dec 20, 2022 • The Watches
1helpful
I have a 2003 Croton Belagio watch How do I set correct date?
To set the date on your Croton Belagio watch, you will need to follow the steps for setting the date on your particular watch. Every watch is different, so the specific steps will depend on the make and model of your watch.
Here are some general steps that you can follow to set the date on your watch:
If you are unsure of how to set the date on your watch or if you are having trouble, you may want to consult the manual that came with the watch for more detailed instructions. If you do not have the manual, you may be able to find a copy online or you can try contacting Croton customer service for assistance.
I have a digital wrist watch and I can not set it up.
hi Claude.
Press and hold the "Adjust" button to until the "Time" digits begin to flash. Use the "Start/Stop" and "Split/Reset" buttons to set your digital watch to the correct hour and minute increments. Press "Mode" to display the "Date" setting screen.31 Mar 2015
Digital Watch Instructions ' Techwalla.com
https://www.techwalla.com/articles/digital-watch-instructions
How do u set a digital watch?In normal time mode, Hold L2 for 2 seconds to alarm time set mode, then L2 again to normal time set mode, the second digits begin flashing. Press R2 to reset the seconds to "00", press R1 to switch to the minute digits. Press R2 to advance the minutes. Press R1 to switch to the hour digits.4 Button Digital Watch - Dakota Watchhttps://www.dakotawatch.com/PDF_FILES/Digital.pdfSearch for: How do u set a digital watch?
how to set digital wrist watch Google Search
Nov 27, 2017 • Watches
How to set pocket watch
Hi John, There are several possiblitites depending on the watch you have. If it is a battery watch you set it like most modern watches by pulling the pendant and the hands should move. If it is a vintage watch it may set the same way. If gentle pulling the crown does not work try this. Your watch may be a lever set watch. This requires removing the crystal of your watch will be screwed on. If it doesn't loosen easily try putting the watch between your palms and twist. Once the crystal and bezel loosen remove it and set it aside. Now look near the 2 o'clock position. A lever set watch will have a small metal piece sticking up that is designed to be hooked with your fingernail and pulled out. When in the out position your watch will now be in the setting position and your hands will move when you rotate the crown. After setting push the lever back in and you will now be in the winding position. Replace the crystal and carefully screw it down but not too tightly. There are other systems but I am guessing this will cover your watch. Merry Christmas
5helpful
2answers
I accidentaly reset time & date on my square arnette watch and i need help to set it
Thank you for contacting FixYa.
    Set Digital Watch
  1. Press and hold the "Mode" button on the right side of your Arnette digital watch for three seconds to change the watch's mode. Press and hold the "Mode" button repeatedly until flashing digits indicate that you have entered the watch's time-setting screen.
  2. Use the top and bottom buttons on the left side of your Arnette digital watch to increase and decrease number values as desired.
  3. Press and hold the "Mode" button repeatedly to exit the time-setting screen and return the watch to time-telling mode.
  4. Set Analog Watch
  5. Pull out the watch crown on the right side of your Arnette analog watch.
  6. Turn the watch crown clockwise to adjust the hands of your Arnette analog watch to the appropriate time.
  7. Push the watch crown back in when you are finished setting the time on your Arnette analog watch.
Best regards. Jewel
Sep 09, 2010 • Watches
1helpful
Setting a Casio Wave Captor watch after battery change
If the watch is running try to sync the watch 1st, meaning set the minute and hour hands pointing to 12:00 o'clock. before you go to set the time.
2helpful
2answers
Timex Watch
While the time is displaying on watch press & hold the set/indiglo or top left button on watch. The seconds should start to flash.
Press the mode or bottom left button until the hour digits start to flash.
Press top right or start/stop button to advance the hour. Then press top left or set/indiglo button to exit set mode.
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
