Using a test lamp, check to see if power is getting to the relay when you turn on the headlight switch. If not, the switch probably needs to be replaced.
I suggest you get one of those manuals people get nowadays to do it
yourself.. My nephew use it to repair my car and it's totally repaired now. Here's the website he bought it from.
this is usually a sign that the flasher relay needs replacing,these are usually located behind the drivers kick panel , you can locate it whilst the flashers are turned on , just feel which relay is clicking
3.0 Liter V6 engine use Dayco 95257 2.2 Liter 4 cyc engine use Dayco 95199 ========94167 is an old Deyco Euro part # It will fit the following Toyota Camry 2.0 i19963S-FEPetrol10/86-06/91
Toyota Camry 2.0 i 16V19983S-FEPetrol10/86-06/91
Toyota Camry 2.2 i 16V21645S-FEPetrol06/91-07/01
Toyota Carina E 2.0 i 16V19983S-FEPetrol02/92-10/97
It sounds like the seal in the washer pump has worn and let washer fluid into the little motor, causing it to corrode and seize. Pump is usually located on bottom of washer fluid bottle.
more than likely it is a horn fuse or relay, never seen the button go out on then models. both r under the hood. to check relay swap with one just like it tosee if it works. good luck
