The original length of deck belt is Deck Length 96 1/2" Type Covered Width 1/2". Fits Model. CUB CADET : LT1040 and LT1042, 42" ...
and pls vote me as helpful if it is
If the belt is in one piece, put a chalk mark on the back of the belt and measure the length by running a tape measure from one side of the mark all the way around the belt until the mark appears. Take that measurement, subtract an inch for stretch and that number is the number of the belt you need. If it's broken in two, not three, then simply measure the length of the belt.
Make a drawing of the deck routing and pull the belt off the mower measure the width and length of the belt and order one on line or go to a mower shop with the belt and they can size it to the one you need. Do the same for the drive belt.
Just in case anyone else comes across this in searching for a Main Drive Belt or a Deck Belt :-
Marksman Industrial Ltd
Main Drive Belt 1134.9013-01 (see also 9585-0057-00)
External length 888 mm
"STIGA 1134-9013-01 Equivalent Belt" Kevlar reinforced
Deck Belt 1134.9032-01 (see also 9585-0075-00)
External Length 1219 mm, Pitch Length 1206 mm
4L480K - 1/2" x 48" Kevlar reinforced
Note:
Stiga Garden Combi is pretty much an identical mower
Your mower uses the #144200 belt by A.Y.P. This belt is 1/2" by 88.3" You must use a wrapped belt for this application. The #144200 is available through www.searspartsdirect.com and will also be readily available at your local repair shop.
Sorry, we have no belt listing for your specific model, but we do likely have what you need........
If you still have the old belt intact: > Lay it out flat on the table > Pinch it at both ends & straighten the belt but don't stretch it. > Measure the length & then double it and choose or we will recommend a size about 3-5% smaller.
Old belt too far gone to measure: > Just use a piece of string and thread it temporarily in place of where the belt goes. > Then measure the length of the string and Email us the exact length (inches). Along with your EXACT model number. If your belt has a round or square cross section, please give us the thickness as well. We can assist you in choosing a belt usually 3-5% smaller than the length you measured.
....from the turntableneedles.com site
