Question about HP Compaq nx6110 PC Laptop
HP compaq nx6110 hang problem
I have problem with my laptop, i do not know what is happened,suddenly it died, then i take it to maintain, after that it work but it hange every time and work when i move it , if i move it again it hang again.
I need a manual to use with my computer so I know if it still works.
HP Compaq nx6110 Notebook PC Manuals ' HP ...
h10025.www1.hp.com/ewfrf/wc/manualCategory?...
Hewlett?PackardManuals or User Guides for your HP Compaq nx6110 Notebook PC.
HP Compaq nx6110 Notebook PC - Manuals - HP Customer ...
support.hp.com/us-en/product/HP-Compaq...Notebook-PC.../manuals/
Find support contact options like chat, phone or email specific to your HP Compaq nx6110 Notebook PC including Service Locations and Check repair status.
Manuals for HP Compaq nx6110 Notebook PC - HP Support ...
h20000.www2.hp.com/.../DocumentIndex.jsp?...Suppo...
Hewlett?PackardHP Compaq nx6110 Notebook PC. Warranty status only indicates current warranty state. If you have an active Support Agreement or HP Care Pack, you can link ...
[PDF]Maintenance and Service Guide - tim.id.au
Jan 24, 2016 | HP Compaq nx6110 PC Laptop
Compaq nx6110 laptop hangs after 30 minutes, please help
It should caused by a power supply too weak or not stable problem.HP Compaq nx6110 PC always happen to this problem.
Feb 10, 2011 | HP Compaq nx6110 PC Laptop
My usb ports are broken and i want to find a new onw please help me
Take a look at this post that deals with a HP nx6110 laptop with random freeze ups. If the described symptoms also happen on your laptop. If you do experience random freezeups or slow DVD you're facing the same FSB chip problem. All peripherals, USB ports included, are connected on the Front Side Bus. Poor soldering causes intermittent contact which in turn results in hanging, slow, or totally non bootable (stuck at HP logo) laptop. Hope this helps.
Nov 26, 2010 | HP Compaq nx6110 Notebook
My HP compaq nx6110 windows xp sp3 hangs at boot
Nov 14, 2010 | HP Compaq nx6110 Notebook
Hp compaq will not boot, sticks at hp invent screen with F10
Take a look at this post that deals with a HP nx6110 laptop with random freeze ups. See if the described symptoms also happen on your laptop. If you did experience random freezeups or slow DVD you're dealing with the same FSB chip problem. All peripherals, USB ports included, are connected on the Front Side Bus. Poor soldering causes intermittent contact which in turn results in hanging, slow, or totally non bootable (stuck at HP logo) laptop. Hope this helps.
Oct 26, 2010 | HP Compaq nx6110 Notebook
Laptop hangs problem hp nx6110
The only way to cope up this problem is to replace south bridge chip of the laptop.
Oct 16, 2010 | HP Compaq nx6110 PC Laptop
HP COMPAQ NX6110 LAPTOP HANGS WHEN BOOTING, BUT WHEN PRESSED AROUND THE MOUSE PAD OR HARD DISK AREA IT WORKS , BUT HANGS AGAIN LATER
It seems that the hard drive or the memory module is not seated properly and hence after pressing on the area below keyboard it gets released.
You can try following things.
Remove and reseat the Hard drive.
And remove and reseat the Memory.
Try to power on the laptop again.
If is getting hang again then you may need to do the HDD self test and memory test built into BIOS.
May 26, 2010 | HP Compaq nx6110 PC Laptop
Hp nx6110 laptop keeps hanging but works well when pressed on top of touch pad or hard drive.
hmmm..that sounds like a motherboard problem about to happen. you have warranty coverage on this unit? also, you may wish to turn over the computer, remove battery, get static off your hands, then remove and reseat the memory cards underneath(most likely behind a small panel with a small phillips head screw).
Oct 07, 2009 | HP Compaq nx6110 PC Laptop
In capsule my nx6110 compaq hp hangs at bios(hp screen)
sorry boss i can get you problem.. please i guess you have not mentioned your problem.
Jun 14, 2009 | HP Compaq nx6110 PC Laptop
Compaq NX6110 BLANK SCREEN!!
Does the screen come on when computer posts and then go blank?
If so then try strting it in safe mode (F8)
Have seen this happen on a friends machine though it worked now and again until laptop was moved slighty. I dismanteled it and it turned out the motherbaord had liquid damage and was corroded :(
Sound like the onboard graphics is faulty...sorry not good news :(
Dec 26, 2007 | HP Compaq nx6110 PC Laptop
HP Compaq nx6110 PC Laptop Logo
220 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
