Question about NetGear RangeMax WPN824 Router
Wireless Router Setup
I just moved and went from cable modem to DSL modem. Tried to reconnect my router via ethernet to the DSL modem and then cannot get internet access on desktop. Am I missing something in the setup?
There are a few things that might be wrong here. So let's go over the basics.
First off, make sure that everything is connected in the same way that it was previously. You have probably done this, but double check.
Second, try connecting your computer directly to the DSL modem through the ethernet cable. This will confirm where the problem has arisen. If you can get internet this way, but not after going through the router, than move onto the next step, otherwise, something has gone wrong in the DSL modem, or somewhere else, and it does not concern the router.
Lastly, your cable modem may have been only a modem, which means that it did nothing other than give you internet access. However, with many DSL providers, the "modems" they supply you with are more of a 1-port router than a modem. What I mean by this is that there is a good possibility your new modem blocks it's connection on certain ports.
Many DSL modems have a function to make them act as only a modem, and let a router do its job separately, but this will be specific to your modem. You may want to contact your ISP about this further.
Anyway, I hope this helps, and I wasn't too confusing. Good Luck!
Posted on Nov 15, 2007
A friend of mine has this D-Link DSL-2750U router & is trying to connect his cable internet to the router but failing to do so. We suspect it is a purely ADSL router & does not support ethernet connection...
You need a router which connects to ethernet..ADSL is connected by RJ45(Telephone connection) ... Many cable companies include a router in the Modem (Verizon) others need a router to do wireless which gets connected between the PC and the Modem . the DSL-2750U is well over $2000.00.. a normal wireless router is $50-$100... a regular router gets connected by ethernet to Modem and router ,, then has 4 other connectors .. ehternet to PC.. Also requires power supply. .. wireless has to be setup for the software.
Oct 28, 2013 | D-Link Computers & Internet
Won't connect to internest.
first there should be 2 cables connected the device.
1) power adapter
2) ethernet cable from either a dsl modem or a cable modem connected to the wan connector
with most cable modem service its usually dhcp meaning you are always connected to the internet
with some there is ppoe connection where a user name and password is used to make a connection to be on the internet with the dsl modem
there are some dsl companies that are dhcp just like the cable modem companies.
with the ethernet cable connected the wan port on your router there should be some kind of activity light on the router but check with the type connection from your dsl or cable internet provider. also you will need a second ethernet cable to connect your computer to setup and configure the wireless settings and wep protection.
need more info?
Aug 24, 2011 | NetGear WNR2000 Wireless Router
Do not know what I am doing wrong to hook up my router to my DSL modem in order to get wireless
Make sure the line coming from the DSL modem is going into the Ethernet plug on the router. Connect via wireless to the router... then log into the router and complete setup for everything else.
Mar 12, 2011 | Computers & Internet
Have 2 computers connected to Netgear WGT624NA router via ethernet connectors and have operated well for over a year. Now have gotten DSL and have run phone line to modem and via ethernet cable have...
Have you tried to reset router. It has to be done in order.
1. unplug router
2. unplug modem
3. shut down computer and restart after waiting 1 min
4. after restarting computer plug power back into modem and wait for all the lights to start blinking
5. after the modem is working plug power back to router and plug in the computer with ethernet cable and make sure you have internet,
6. try to link up with wireless,
If this does not work you will have to setup the router for wireless if it is att wireless you will have to call them to give you the password to set it up.
Jan 10, 2011 | NetGear WGT624 Wireless Router
I recently moved from Cable ISP to DSL ISP service. For the DSL service, I was asked to configure my Router to use PPPoE with Dynamic IP addressing. I also provided the router with my username and password...
The reason you have no internet is because the router is specifically for cable. your description contains errors what i think you mean is that you have gone from cable dsl to an adsl, correct me if i am wrong. Basically your modem connected to your router via an ethernet cable and then the router fed the wireless signal to your wireless devices or via ethernet through the 4 ports in the back. With adsl you have a feed from your phone line to an adsl modem so the only way for you to get the dsl router working is to have two ethernet leads connecting to your pc, one from the modem to the pc and one from the pc to the router. You would also need to setup internet sharing on the pc thats connected to both devices.
Either do it that way or buy an adsl router
Nov 10, 2010 | D-Link DI-624M Router (DI624MRE)
How to set up wbr-3406 tx router with dsl modem
Take an Ethernet cable, and connect the Ethernet port on the DSL modem to the WAN port on the router.
Take another Ethernet cable, and connect one of the LAN ports on the router to the network-port on your computer.
Now, you should be able to web-surf.
Access the web-server inside the router, and run the "Wireless Network Setup Wizard", to configure your wireless networking.
Jun 24, 2010 | CP International WBR-3406TX Wireless...
Wireless connection works fine from the d-link router but the desktop linked from the phoneline keeps going offline. Why?
You've omitted some information about your hardware & configuration & connections.
You should have:
1. cable-modem connected to cable socket (or DSL-modem connected to telephone wall-jack);
2. router connected via Ethernet cable to the cable-modem (or DSL-modem)
3. desktop computer connected via Ethernet cable to the desktop computer
4. wireless device (iPod or netbook or notebook) connected over the "ether" to the router -- this connection will stay "up" almost "forever" (as long as there is AC-power to the router and power to the wireless device).
Which parts & connections do you have?
Dec 26, 2009 | D-Link Computers & Internet
How do I hook up a wireless router to dsl
Simple enough the setup will be as follows:
DSL Modem---->Wireless Router----->Computer
all you need are the proper cables like the ethernet or rj45 cables to connect your modem to router to computer....
for further assistance please provide complete details of the name and model number of dsl modem and wireless router....
Oct 24, 2009 | Belkin Computers & Internet
Can I use my router just as a Wireless router with a DSL .
i doubt it will work. most times the cable companies give you a modem/router all in one box. the problem is there in no inbound connection to recieve an internet signal other than the cable cord connection. with the dsl modem you will need a seperate router. they cost around $40-50 on avg
Feb 05, 2009 | Arris SURFboard SBG900 Wireless Router...
Belkin Wireless G Router causes loss of internet connection
Does your router have one LED lamp for each "wired" port?
If so, does unplugging the Ethernet-cable (the one that connects to your desktop PC) cause the lamp to go off?
Does reconnecting that cable cause the lamp to go on?
Also, on your desktop computer, there could be a lamp right beside where the Ethernet-cable connects into your computer.
Again, disconnect the cable, and reconnect the cable, to see if that lamp goes off/on.
Have you tried a different cable?
Do *NOT* connect your desktop computer to the 'WAN' port on the router -- connect it to any of the "LAN" ports.
Dec 22, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
NetGear RangeMax WPN824 Router Logo
160 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
