Rank: Guru
Rating: 86%, 104 votes
Try this out, Power on your PC, as you are doing this, Keep tapping the F8 key, you should see the options available for booting there, so just select normal, if it happens again, repeat the same process and select last known good configuration. If again it goes into safemode, then do this, : After booting in safemode, right click on your harddisk, then go to properties, then select Tools, then you'll see error checking, just click on Check now, then it will prompt you that it will do it at the next system restart,
Comments:
Jul 11, 2009
- Try this out, Power on your PC, as you are doing this, Keep tapping the F8 key, you should see the options available for booting there, so just select normal, if it happens again, repeat the same process and select last known good configuration. If again it goes into safemode, then do this, : After booting in safemode, right click on your harddisk, then go to properties, then select Tools, then you'll see error checking, just click on Check now, then it will prompt you that it will do it at the next system restart, so just say ok, then allow it to scan your system at the next system restart.
Hope it helps you out.
