Porter Cable 75182 Variable Speed Router Motor Logo
A
Anonymous Posted on Jun 22, 2015
Hi! Do you have this device variant for 220v/50hz?
1helpful
Can i use a 50hz 220V SPLIT TYPE AIRCON TO 60HZ 220V
you probably can but it will be damaged over time, you would need to replace the motor inside to handle 60hz using the 50hz can do damage to the motor, or even cause a fire. also if it has a power capacitor that asys 50hz on the power line to the unit inside this would been changing as well.
How to operate a AEG Washing Machine Electrolux 50hz with 60hz power supply?
In general, it is NOT recommended to operate an appliance 50hz-to-60hz OR 60hz-to-50hz UNLESS the manufacturer specifically says it can do it.
Additionally, you must also account for the voltage (110V vs 220V), which you have not indicated.
Therefore, it is best to get your exact model number and contact the manufacturer, but get ready for disappointment. The larger and more complex the electronic device, the less compatible it is.
Good luck.
I am in a 220C.50 Hz country Are all the XL2400 lamps the same, or different models for various voltages and frequencies
XL2400 lamp are same every where and can be used in Sony tv either in 110V 60Hz or 220V 50Hz
Hope this will help.
Thanks.
Can I run a US bought PS 3 (120v 60Hz) unit on a 220v 50 Hz power system?
Yes you can,,as i am running Canadian bought ps3 in Pakistan 50hz 220v
Hi, Will the krell kav 500i work on 220v 50hz supply? Thanks
If it has a voltage selector for 220v, once configured it will work just fine Being electronic instead of mechanical the power frequency won't affect it. If it doesn't have a voltage selctor, don't plug it into 220.
1helpful
2answers
Kitchen aid stand mixer bought in US, moving to Europe, 220v 50hz
I can not respond to the warranty issues. My kitchen aid mixer is past warranty as well. I live in a country that uses 220V and my kitchen aid mixer is 110V. I have been using my kitchen aid mixer for almost 4 years with no problems at all.
The converter boxes are supposed to blow the fuse on the converter before it reaches your appliance and cause any problems.
If you purchase a 220V kitchen aid (although it would cost more money) it would probably have more power because of the higher voltage.
Hope this helps!
1helpful
2answers
110V 6ohz - 220V 50hz
Kitchenaid mixers are not recommended on the use of a converter as they are not tested under such conditions. Understanding this, using a convertor on your mixer may automatically void the 1 year warranty regardless of age.
There are international Kitchenaid dealers available if you are requiring 110V. You may contacted Kitchenaid Customer Service for more information.
Their toll-free telephone number is 1-800-541-6390.
2answers
Different HZs problem (from 60Hz to 50Hz)
Yes there are frequency converters available but most are relatively over rated (industrial) for your requirement such as MDS Power or VisiComm Industries. What you need is a Low Power Solid State Frequency Converters lower than a
Electrocon Frequency Converters. However, I expect this devices to be rather expensive.
A few other options you may want to consider:
1. Contact the store where you bought if from; swap with an International version (Model SL-1210 Mark II; same price as SL-1200 Mark II); dual voltage switchable on rear of unit: 120 volts/60 Hz (U.S.) or 220 volts/50 Hz (Europe). You hopefully just spend for the cost of shipping + a restocking fee;
2. Contact 3rd party Technics TT specialist like TopDJGear, Quality Electronics, Planet DJ or DJHardware
and inquire if they would supply you the part(s) that you need to convert the 1200 to a 1210; or
3. Offer a swap on eBay.
Hope this be of some idea/help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Top Porter Cable Tools & Hardware - Others Experts
Jay Finke
Jay Finke
Kardoc
deton8 von Splosion
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
