Question about Sony Cyber-shot DSC-W80 Digital Camera
I have a blue tint/haze to my shots. - Sony Cyber-shot DSC-W80 Digital Camera
  • 217 Answers
You might have damage your camera accidently. Go to the nearest service centre.They will help you out.
Posted on Jul 11, 2009
2 Suggested Answers
Bogdan
  • 198 Answers
SOURCE: Blue tint when shooting aperture priority
Hello, First of all let's explain what aperture priority does in terms of electronics and mechanical/optical changes in the way the camera takes photos. Unlike most point and shot digital cameras, your one has variable aperture range. Aperture is related to your camera lens. Their main function will be to collect light and direct it to the camera's sensor. The aperture of a lens is the diameter of the lens opening and is usually controlled by an iris.The larger the diameter of the aperture, the more light reaches the image sensor. Aperture is expressed as "F-stop", for example F2.8 or f/2.8. The smaller the F-stop number (or f/value) the larger the lens opening (aperture). This means that when you're using aperture priority or large aperture values (a smaller f/value) your image sensor (ccd or cmos) will tend to receive more light or slightly overexpose itself. Most simple digital cameras, the point and shot ones, have a fixed aperture, the lens are fixed and that's set to a so believed "optimum" range in order to produce best pictures when using automatic settings. SLR or semi SLR digital camera's woun't achieve best performances when using them on automatic settings, they aren't designed in the same way as the simple camera's. These camera's will tend to either overexpose, or have lighting/colour problems or achieve blurry images when using automatic settings. Any SLR or semi SLR camera user will be required to understand the way photography (electronic photography) works in order to achieve the best performances with it's camera. For your example, I guess the shots have a blue tint on them when you're using natural sun light in your photos, or in room pictures are illuminated by natural sun light. This is the first sign of overexpure, and the best way to reduce it and it's efects is to manually set the aperture range. Note that higher values will reduce the light that passes to the sensor, so you will want to experiment a little with those in order to achieve the best performance. When you take photos in light environments, bright sunny days or in rooms that contain many white surfaces or walls (these reflect the light pretty much and can overexpose the camera even if it doesn't look that bright when you look at them with your own eyes) you may want to use larger aperture value in order to have little light come to the sensor. Look for the highest values in aperture (in your menu) for example F8 or F16. If the pictures come out to dark or miss some details, you may want to use larger apertures (smaller numbers). Try these tests in order to check if your camera's problem can be solved this way. If not please reply back and we will look on the hardware - firmware side of the problem. Regarding aperture a quick recap :) A large aperture allows more light to reach the sensor. It's good when taking portret pictures and also achieves that nice blurry background surrounding your main subject in the picture. It's defined by smaller numbers (for example F1.8 or F1.2 or smaller). A small aperture allows little light to reach the sensor. It's good to take pictures in bright sun light. It's defined by larger numers (for example F16 or F22 or larger). Hope this helps, Bogdan.
Posted on Jul 01, 2007
HPL1906 screen has a pale blue tint / haze over that flickers over the screen I tried the buttons on the bottom of the monitor but they just changed intensity of the tint/haze
Try the monitor on another computer first, and check the security and condition of the VGA lead pins.If any are bent or missing that could be the problem. A missing pin will account for part of the signal not being sent from the graphics card to the monitor and could give the blue tinge. Loose connections are also culprits here.
Check there are no strong magnets neat the monitor.
Try a different monitor on your computer.
After that, I think that your monitor could be failing.
Jul 25, 2011 | HP Computers & Internet
My 60 inch phillips television has a red tint to it it was made in 2003
Usually this is bad fluid in the blue and green CRTs. the tell-tale sign is that the blue will just haze,
look at a guy in a black suit.. you will see the blue just hazing out around his white shirt and tie. This is common for all these philips TVs and is dirty cooling fluid in the blue and green CRTs. A repair shop will charge you about $300 for the fix, maybe less if you're lucky. You could fix yourself for about $40 and some time, but would need to have some mechanical skill and some free time on your hands. Let me know if you need further assistance.
Jun 14, 2010 | Televison & Video
I have a Hitachi 55VS69A television. I replaced the bulb and not long after I did that I had a blue haze in the center of my screen. The blue haze spread to the right hand side of the screen, and now...
I have a Hitachi Ultravision. 55VS69A. It has worked wonders but now there is a blue screen in the center of the tv. Should I just replace the bulb. thank you.
alex
Apr 19, 2010 | Hitachi 55VS69 55" Projection HDTV
Can't fix the color - really blue or really yellow.
Probably Blue CRT shot. Put tint back to center and turn color level to 0. Should look good black and white pic. If blue CRT shot, will look yellowish; usually more yellow around perimeter.
Apr 14, 2010 | Samsung HCM4215W 42" Rear Projection...
The screen has a blue like tint around the edges of the screen..what can i do? it's a magnavox 6p6030w101 60inch projection tv.
you have coolant in your red, green, and blue picture tubes. this coolant will start to turn dirty as time goes. the coolant should be clear but when it starts to turn, your picture has like a haze in it. coolant needs replacing. suggest local service center
Nov 08, 2009 | Televison & Video
BLUE TINT ON SCREEN ALL THE TIME, COLOR ADJUSTMENTS FINE
Sounds like a bad blue CRT (picture tube) ITs expensive and difficult to replace. CAll a Sony service center for an estimate. but expect to spend $500-700 to replace it.
michtech
Feb 18, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Blue haze in lower left corner on screen
if you have any speakers near the screen the magnet may be causing the problem. i had a similar thing happen & when i moved the speaker the problem went away
Jan 02, 2009 | Televison & Video
Blue haze spot-yellow tint
I have the same problem with blue haze that just spread out on model 55VS69A ,
tv is almost 2 years old. i called hitachi and they advised to call a local repair center to check the tv...they confirmed Optical Block (light engine ) replacement light engine cost $1400 and labour $400, so i called back hitachi and they said they will provide light engine and will have to pay labour!....this is not right paying out of pocket for a tv less than 2 years old....I am not sure if the issue will resurface again...more likely ....Hitachi is supposed to issue a recall or atleast like sony did to cover all cost for there defective TV's....I will NEVER buy hitach again.
Hitach SUCKS.
Dec 28, 2008 | Hitachi 60V500 60" Rear Projection...
Greenish tint
Not sure if this is the solution, but I believe the color polarizer filters have been burned. I have a yellow haze circle on mine and I'm pretty sure that's the problem. In my case the blue filter is burned, leaving the red and green stronger yeilding a yellow blur.
Aug 27, 2008 | Epson - PowerLite S1+ Multimedia Projector
Blue haze on hitachi 51" tv
I finally emailed Hitachi about the blue haze and since my televison is only 16 months old they agreed to pay for the part (they didn't say what part) and I will have to pay the service charge. The repairman is coming out on 2 Apr 08. I will post results after that.
Mar 09, 2008 | Hitachi 50V720 Television
Sony Cyber-shot  DSC-W80 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Terry Weaver
Terry Weaver
Are you a Sony Camera Expert? Answer questions, earn points and help others
