Question about Kitchen Ranges
Hotpoint 30" self cleaning gas range with sealed burners - no bake
15 months old. burners and broiler in upper oven getting gas and work, but bake does not. instructions said to reset switch on regulator. did nothing.
i see two igniters, one for broil, one in lower oven for bake. bake does not light. wires look okay and attached. does the igniter need to be replaced? does the whole burner assembly have to come out? used the self-clean feature 4 times in the last year. bake stopped right after the last clean two weeks ago. how long should a ceramic igniter last? where can i buy? help. thanks.
  • dledteacher Dec 01, 2008
    I put the oven on self clean and four days later the oven would not come on the broiler works but not the oven. I need help. The oven is only four years old.
  • Anonymous Mar 23, 2014
    Tank you for the help- Two of the four burners burn too low and therefore take twice as long to use. I cannot find adjustment instructions. The burners worked correctly for 8 years.
    Kitchenaid 30" sealed burner gas slide in range, Part no. 9755235.
  • 3 Answers
It may be the ignitor, they can crack and you wouldn't even see. Good news is they are cheap ($5-20) and they are usually easy to replace. But before you replace it...
When set to bake, does the "oven cycle" light come on? If not, that means no power is being sent to the ignitor. Reason? There is a switch in the oven latch, to make sure a) latch must be closed for cleaning cycle and b) latch must be unlocked for baking. On mine, the switch button gets stuck, so even when the latch is unlocked, it thinks it is locked and will not allow the bake cycle to proceed. Cycling the latch a few times may free it, otherwise you'll need to replace the switch (not that hard but a bit of a pain to get to).
Posted on Nov 22, 2007
Broiler shuts off
Make sure you keep the oven door OPEN when using the broiler, otherwise the thermostat will shut it off.
Jan 18, 2013 | Maytag Gemini MGT8655X 30" Freestanding...
I have a GE XL44 gas range. My Broiler goes on then off, on then off what could it be?
if this is a self cleaning model with the broiler at the top of the oven then i would guess that you may have an ignitor going out. is the bake working ok?
if this is not a self cleaning model and the broiler pan is underneath the oven then it uses the same burner as the bake. if this is the case you should also be having trouble with the bake function.
May 28, 2010 | GE Kitchen Ranges
OVEN NOT HEATING, BROILER AND BURNERS WORK
The first thing to check is the wiring and make sure it is all secured and connected properly.
Then check the bake element and use an ohm meter to check for continuity,if there is no continuity the replace the element.
if those items are good then you will need to replace the electronic control boardor commonly called the clock timer.
Mar 03, 2010 | Hotpoint 30" Self-Cleaning Freestanding...
The broiler works but the bake option doesn't work, the oven doesn't get hot, any suggestions?
Check the bake ignitor (glow bar attached to the burner). If it does not glow at all, but the voltage is supplied to it - replace. If it does glow, but draws current less than 3A - replace.
Oct 14, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
My maytag gas oven model #MGR5755QDW makes a loud poof noise when first turned on. It doesn't do it all the time and it only happens when it is first lights.
You are getting a delayed ignition fom the oven burner. Either the ports on the burner near the ignitor are clogged or you have a weak oven ignitor. part # 12400035 @ $70.00
Apr 08, 2009 | Maytag 30" Self-Cleaning Freestanding Gas...
Broiler works, but oven does not.
oven is equiped with two elements one,< upper > for broiler and the second < lower > is for baking . The bake element is probably damaged and no longer working,< damage is just from use the element has failed >, to know for sure element has to be tested for continuity to confirm this,< unless it is obviously damaged, broken or burnt and seperated >.
Apr 01, 2009 | GE 30" Self-Cleaning Freestanding Gas...
Broiler works, as do burners. The oven will not come on. Gas whirlpool range 2003 year. Model SF367LEKB
jdelvecchio5Does the igniter (glow bar) come on whenever the bake function is selected.?
If the glow bar does not come on the safety valve will not open - no bake burner. check the electrical harness first then Try changing the igniter (glow bar first) before changing the safety valve/regulator.
Dec 02, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
338 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
