Question about JBL GTO937 Car Speaker
Hi bought jbl gto 937 speakers,next week going to buy a 200 rms amp for them but here is a problem,have no idea what wiring kit should i need.There are loads to choose from but need some help on choosing the right one can anybody help?Thanks
  • a_vital84 Jul 11, 2009
    amp is 2x75watt at 2 ohms
  • 655 Answers
Hello a_vital84,
You can safely use 8 gauge power and ground up to about 400-500 watts RMS. Actually, for the current your amp will draw, even at maximum power, a 10 gauge would suffice. But the difference in price is so minimal that it makes no sense to buy a 10 gauge wiring kit. Who knows, you may decide that the amp doesn't provide enough power and want to go to a bigger one, in which case you'll already have the proper size wire pulled. Just select a brand name kit that includes ring terminals, fuse, and RCA input cables. The most economical are Metra and Scosche. Streetwires (by MTX) and Monster Cable are more expensive. And some branded Rockford-Fosgate or Kicker will cost you the most. But they will be the very best kits with oxygen free copper and all of the needed installation hardware. You can see a variety of amp wiring kits at www.crutchfield.com or www.sonicelectronix.com. Either online store is a good place to buy from also. The Crutchfield site also has loads of good information that is well worth your browsing time.
Hope this helps.
Posted on Jul 12, 2009
Car amp
I cannot understand the problem , do you need the diagrams
Apr 10, 2008 | Car Audio & Video
Toxic tx 600 amplifier
You need to get another amp for your sub. I would say if you want good quality go for MTX because I have had amps from MTX and never had a problem. what you need to know is look at the fuses on the amp if there are 3 of the 25 amp fuses on there then it should push out about 750 watts but on MTX they under clock the amp so it will push about 800 at 14.4 volts for that you will need a 4 gauge wiring kit with a 60 amp fuse in the fuse link. As far as your other amp hook up the speakers and tweeters to that but be sure to tune in down and you would need a 8 gauge wiring kit. I hope this helps you.
Jul 27, 2010 | Car Audio & Video
Selecting an amplifier!
Buy a quality 2 channel amp. About 600 rms and set one channel as your highs using your crossover and then the second channel on "low" position for your sub. wire directly in to your low's channel with your sub at 2 ohms and then wire your speakers to the other channel.
May 23, 2010 | JBL GTO937 Car Speaker
How i wire my sub to my jbl gto301-1iiamp with 2 Hifonics HFi12D4
If the amp is 1200 watts at 2 ohm stable you will want to set up the speakers as parrallel and bridge the amp. That means conncect the speakers with + to + and - to -. Look at the amp connections. Usually thereare connects that look like this:
If yours look like this use the diagram on top. You will use the + for the left ouput on the amp to the right - on the amp. This will allow you to use all the power from the amp. Be sure to lower the gain as to not pop the speakers or amp.
Nov 17, 2009 | JBL GTO 301.1II Subwoofer Mono Amp - 200W...
Finding the best amplifier
Hello sharky75,
That 1600 watt peak power figure for your subwoofer can't tell you what amp you need. You need to know the maximum RMS power the sub can handle. And you need to know the impedance (ohms) of the voice coil(s). JBL GT5 series subs have an RMS rating of 275 watts. The GTO series handles 300 watts. The Power series handles 400 watts. The GTi series handles 700 watts. Some are single voice coil, so the impedance is fixed. Others are dual voice coil allowing you to wire them for different impedance loads.
For maximum performance your amp should be able to provide at or near the same number of watts RMS into the lowest impedance at which the sub can be configured. For example, if your sub is the Power Series Model number P1224, it has dual 4ohm voice coils and can be wired to present either a 2ohm load (parallel) or an 8ohm load (series). You want to wire the voice coils in parallel for the 2ohm load and select an amp that outputs up to 400 watts RMS into 2ohms. The Orion Cobalt CO8001 is just such an amp. If you have one of the GTi Series subs, a better amp would be the JVC Arsenal KS-AR75 which outputs 700 watts into 2ohms.
Hope this helps.
Jul 31, 2009 | JBL Power P1022 Subwoofer - 10" Dual 2...
Hi,just bought a 6x9 jbl gto937 speakers for my car,each speaker is 100watt rms and 300 max .Can anybody advice on what amplifier should i get for them?I know i can run them without any amp but think they...
Pyramid makes the PB series of amps. I have one that's driving a Sub.
The PB 700 puts out rms 60watts x 2 @ 2ohms, which gives you some "headroom" for your speakers. You don't want to over drive speakers with , for example, a 1000 watts for 100 watt speakers, because that's a good way to blow your speakers.
There are many brands and models of amps that will fit your speakers. Just make sure the amp will drive 2ohm speakers, since your jbl's are rated at 2ohm impedance.
You may want to consider adding a Sub woofer to your setup. A single Sub would fill in the low end very nicely. If you got a 4 channel amp, then two channels will drive your jbl's, and you can bridge the other two channels to drive the Sub. That would be a kick'n sound!
Just make sure the amp is bridgeable
For example, the Pyramid PB 1200 is a 4 channel, bridgeable amp. This particular amp will drive the 2ohm jbl's, but you would want a 4 or 8 ohm Sub connected to the bridged channels.
Jul 05, 2009 | JBL GTO937 Car Speaker
JBL Sub Amp Wiring Please
it seems rather redundant to bridge a mono amp. Unless the instruction manual states otherwise, i would assume that one speaker output is identical to the other (ran in parallel, like an A or B speaker, not like Left or Right), and you would present the amp with a two ohm load by wiring one speaker to each output. Bridging it may or may not work, but, again, it just seems redundant.
Mar 01, 2008 | Car Audio & Video
Jbl gto 3501 amp
It's a mono amp. There's no bridging with this amp.
The two pairs of speaker terminals are connected together internally. The second set of terminals is for convenience.
Dec 21, 2007 | JBL BP1200.1 Car Audio Amplifier
Car Audio & Video Logo
372 people viewed this question
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Marvin
Marvin
Rob Beech
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
