The brake for most saws, routers, etc, is a sprung pin that fits into a slot directly on the arbor. Most times, sawdust and debris gets it stuck. Sometimes, the pin gets worn and rounded and cannot find purchase to stop the blade/bit from turning. I have used spray contact cleaner to unclog the jam up. otherwise, you have to do a little disassembly to get to the pin to unstick/replace the brake assembly. use a scrap piece of wood between the teeth and guard as a wedge to stop the blade so that you can turn the arbor nut.
SOURCE: Need Owners manual for older Craftsman Radial Arm
Here is a site to have the manual Emailed to you
http://www.sawmanuals.com/ Hope this works for you.....Please rate.......
SOURCE: crafstman radial arm saw owners manual model #113-29440
Go to this link and you'll be able to download the pdf file of the operating instructions for you saw.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: looking for craftsman 10 inch radial arm saw manual
Got it. Go to Searspartsdirect.com and on the right side type in your model number and on the next page again on the right is an area for see manual, you might have to set up a free user account to download this manual 35 pages long but it is there. If I have helped with your question would you please rate the response accordingly and thank you.
SOURCE: dewalt Radial arm saw switch
try to find someone on craigs list or ebay selling one for spare parts.
SOURCE: craftsman radial arm saw 113-197751 wiring diagram needed
A friend just inherited a model 113.197110 and we are in the process of trying to restore it. I can draw you the wiring connections if you haven't figured it out yet.
