Question about Homelite Mighty Lite Lawn Trimmer
I am looking for a manual for a homelite gas string trimmer,mighty lite 26vt,where.Engine runs but spool does not turn.
Type in homelitest and ut number on the trimmer and then search google . maybe
Posted on Jul 11, 2009
Changing the spool/ need to place more cutting thread on.
Unable to download your exact model (Mighty Lite) manual. Here are the instructions for stringing a different model with hopefully the same type string head. See pages 14 & 15 of this manual. You will need Adobe Reader installed on your computer to view this.
http://dl.owneriq.net/e/e795beb6-5dd6-4dbd-a82f-57b8d1a69355.pdf
Apr 09, 2011 | Homelite Mighty Lite Lawn Trimmer
I was given a homelite mighty lite 26VT and I can not figure out how to remove the spool to insert the string.
There is a threaded cap on the spool that can get very tight, but a pair of Channel-loc pliers usually does the trick to remove the cap. Getting the string to feed consistently is a trick that I have not figured out how to do...
Aug 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite 26CS Model21004D
Once you have the string wound onto the spool, place the spool onto the shaft and pull the strings out of the slots so that the string feeds through the holes without going through the slots. Good luck...Lee
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite mighty lite 21506a
There wiil be a nut or a knob at the end of the spool where string comes out turn it left to loosen and right to tighten it. Rmove spool pull down and spool will come off foll directional arrows that shows which way the string should go put spool back on tighten screw or some you can turn with knob at end make sure it's tight before starting.
Jul 06, 2010 | Homelite Mighty Lite Lawn Trimmer
Correct gas to oil ratio for Homelite Mighty String Trimmer Model
most trimmers are 50:1. or 40:1. i would use synthetic 2 cycle oil and use the 50:1 ratio. i know guys with trimmers that require 50:1, and they use synthetic at 80:1 with no problems for years. they say the engine runs cleaner. i am a part-time lawn care operator.
Jun 18, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite st-175g trimmer
This is for a duel line trimmer. I hope this will help.
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite string trimmer mighty lite
does it have spark? did you replace the plug?
Apr 29, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
1,192 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Jay Finke
Jay Finke
Are you a Homelite Garden Expert? Answer questions, earn points and help others
