Question about Garden
I lost my manual and I'm trying to locate a rear axle but I would like to see if I need the whole axle or just a part on the end of the axle. Where can I find a picture of this?
  • 45 Answers
If this is an MTD, you can find manuals and drawings here:
http://www.buymtdonline.com/webapp/wcs/stores/servlet/Home_BuyMTDOnline_10101_19502_-1
Click on the “parts finder” to find parts diagrams.
Posted on Aug 14, 2009
I hit the curb realy bad in an accident, my rear right side rim wabbles , I replaced the rim thinking it was jst the rim,!But I think its the axle!,shld I replace the whole rear end?
I dont know whar kind of vehicle or how many miles on it but if its rear wheel drive you can replace either. the rear end will cost more than an axle but if it has alot of miles on it plus you dont know about the rest of the componenents inside do the whole thing
Apr 01, 2015 | Cars & Trucks
How to take out a rear axle 1981 chevy c10 1/2
  1. Support rear of vehicle on jack stands,
  2. remove rear wheels and brake drums,
  3. put drain pan under rear end,
  4. remove rear end cover which will drain the oil,
  5. remove the spider gear shaft so that the axles can move inward,
  6. Push the axle you want to remove toward center of vehicle
  7. Remove C clip from inner end of axle
  8. Pull out axle
Somebody has scanned the whole factory manual and it is available at the attached link as a PDF file
Redirect Notice
Feb 08, 2015 | Cars & Trucks
Need detailed manual or assistance in replacing left rear axle seal and bearing on 2005 GMC Sierra pickup with 5.3L engine and a 324 rear end
You'll need to remove the rear end cover, remove the pin in the center pumpkin, push axle toward the center of vehicle and remove the axle clip, pull out axle. You may need a bearing puller to remove bearing.
Mar 04, 2010 | 2005 GMC Sierra
Need to remove rear axle on 67 camaro can't locate c clips
some older cars do not have c lips. you need to jack up car and place on jack stands withe the whelles off the ground. remove rims/tires. remove drum brakes. remove rear end cover. you need a drain pan under it. you need the car in neutral. spin axle. look in rear end. posi or not you will see the large pin that goes through the middle of the diff. one end of the pin is held in by a bolt. reomve the bolt. spin the diff down. slide the pin out. in side the diff on each side are spider gears. with the pin out push the axle in. this will push the clip so you can pull it off of tha axle and spider gera. then pull axle out. noe an easy or claen job but very doable.
Dec 27, 2009 | Chevrolet Camaro Cars & Trucks
Rear Axle
inside the rear end,you need to remove the rear inspection cover from the rear end.have it jacked up and blocked for safety,and put it in neutral,you will see a slide bar in the center of the rear end it goes in between the side gears.rotate the drive shaft around until you see the end of the round slide that has a 5/16 bolt going thru it. loosen that bolt but don't remove it yet,rotate the drive shaft until the slide bar is almost down at the bottom,but just enoughup to be pulled out and clear the housing.use your left thumb to hold slide bar from falling out while you remove the 5/16 bolt,now let the slide bar fall out to you while your pulling on it.
"VERY IMPORTANT"= don't let any one turn any rear wheels while the bar is out or you will sping the spider gears right up and out of the rear end.
Now have someone push the axle in towards you,when they do a C clip will fall of the axle,you will need to recover it with your fingers or a magnet ,You can now pull the axle out,you will see the groove the C clip was in,When you reinstall push the axle in onlt try not to turn it,you might have to a little to line the splines up,when the axle is pushed in the whole way,insert the C clip and you hold it there while someone pulls outward on the axle that will put the C clip in it's seat,then reinstall the slide bar,you may have to wiggle it a little or just barely turn the drive shaft to get it to go in,reinstall the 5/16 bolt and tighten,install new cover gasket and refill.good luck
Nov 26, 2009 | 2001 Chevrolet Astro
Want to change a leaky seal on a axle shaft on
take off the housing cover in the middle of the rear end and to each side there is a retainer clip for each side. Pull it out and that side comes out. I don't think you needed to remove the rear end to do this though.
Oct 03, 2009 | 1998 Chevrolet Tracker
Is the cv joint part of the axle assemble on a 2003 volvo s80
On the the rear of the car they are part of the axle, on the front of the car the CV joints are connected to the steering rack/rods.
They are located directly behind each wheel like this >>>>>>
Regards.
Sep 04, 2009 | 2003 Volvo S80
Axle came out of rear end
solution was to fing the 10 year old owners manual and look at the exploded diagram..and yes there was a clip holding the axle in...next was the fun task of dropping the rear end and opening it all up.
Oh Boy!
Apr 28, 2009 | Craftsman Garden
I AM TRYING TO PULL THE REAR END OUT OFF MY
You dont have to pull the whole rear end out. remove rear wheel and remove the brake drums. theres 4 nuts on the back side of the brake backing plate which holds the axles in. once you get the 4 nuts loose you can pull the axle out (might need some force to pull out). You should be able to take the differential cover out to inspect the gears.
Apr 25, 2009 | 2002 Nissan Xterra
Garden Logo
65 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
