Question about Black & Decker 3 x 21 In. Dragster Belt Sander
I replaced the sanding belt and now it doesn't move. Why not?
You may have bought a belt that is too small or over tightened the adjustment.
There may also be a chance that if the motor turns and the belt does not move you may have snaped the drive belt. If this is the case please take the tool to your nearest tool dealer.
Regards
Chris
www.powertoolworld.co.uk
Posted on Jul 11, 2009
Why does it cut sanding belts?
the belt alignment is WAY out of adjustment!!!!.. move the alignment OPPOSITE the way it is now..
Jan 25, 2016 | Sander Tools & Hardware - Others
My belt doesn't want to move when you turn it on. Do I need to replace it?
please lube the deck belt+rollers bearing front and rear+test the drive belt motor and replace if necessary.
God bless you
Jun 17, 2013 | Proform 795SL/GL760 Treadmill Front Roller
How to clean a clogged belt sander
I assume you mean you want to clean the belt itself? You can use a rubber stick made for this. It looks and smells like a giant pencil eraser, about 1 inch square and about 10 inches long. However, if the belt is clogged with melted paint, that won't do much - but a stiff wire brush works OK. If the wire brush doesn't work, get a new belt. You can avoid the melted paint buildup (or at least reduce it) if you keep the sander moving rapidly over the surface, and use a good quality scraper to remove as much paint as possible before sanding.
Sep 19, 2012 | Makita 9404 4'' x 24'' Belt Sander
Need part for Mastercraft belt sander 54-7240-8 I need to replace the belt on the motor that drives the belt drive assembly. The motor runs ok but, the wheel that drives the sanding belt doesn't turn...
Anyone has a broken belt sander 54-7240-8 within Canada? I could use a particular part from it to fix mine. If you do, email me at mstevlik@zoznam.sk
Thanks.
Sep 27, 2011 | Tools & Hardware - Others
The sandpaper works its way off the machine almost immediately after turning machine on. We already checked to see if the paper was the right size. We also made sure the tightening lever was secure.
If this is a belt sander then they have a tracking adjustment knob. You will need to adjust it so that the belt stays on and doesn't want to walk off.
Jul 13, 2011 | Makita Tools & Hardware - Others
I have borrowed a ryobi industrial belt sander, I have put the sanding belt and repositioned the latch. When running the sanding belt keeps moving out.
There will be a tracking adjustment somewhere, usually a knob or wheel located at one end (axle) of the sander that allows you to adjust that... run the sander at low speed while you turn it until it tracks straight
Jun 10, 2011 | Tools & Hardware - Others
The Belt of my craftsman 3x21 sander slowly moves off track.
There is a leveling (screw/knob) on the side of the belt sander. Turn it up and the belt will drift in one direction. Turn it downward and the belt will drift in the opposite direction. play with this leveling screw/knob until you reach a good balance and the belt will stop drifting.
Dec 04, 2009 | Craftsman 3 x 21" Variable Speed Belt...
Skill belt sander belt stops moving
most belt sanders are simular,if you have right size belt,there should be a lever between the belt wheels,pull lever out,put belt on,then close lever,some also have adjusting knob,turn clockwise to tighting.
Sep 30, 2009 | Tools & Hardware - Others
The belt slips off my Belt Sander
All sander will have two adjustments. The first is to release the sanding belt by retracting the position of one of the rollers. The second adjustment moves one of the rollers belt tension from side to side. The roller angular position is changed, sometime by a single knob or screw, and sometimes by two separate adjusting screws.
Jun 19, 2009 | Dewalt DW433KT Heavy Duty 8 Amp 3 Inch By...
Sanding Belt Slips Badly
Check and see if the pulleys on the sander are not glazed this somtimes will cause the belt to slip. Give them a good cleaning. If this does not help there is a good chance the spring on the belt tensioner is weak and need changed.
Hop this helps
Jan 09, 2009 | Tools & Hardware - Others
Black & Decker 3 x 21 In. Dragster Belt Sander Logo
242 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
James Ryan
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Axel Gringmuth
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
